Monitor 4 eggcrate/batting placement
I went to epoxy my drivers and the eggcrate was disintegrated... So exactly where should I place the new eggcrate foam and batting?
M7's 1982 Peerless tweeters
M5's X2 (1981 Peerless tweeters, 1988 with upgraded tweeters)
M4's X2 both with Peerless tweeters
M5Jr with SL1500 (in the garage, they sound great)
M4.6 series2 X2 with upgraded tweeters
SDA 2 with upgraded tweeters
Best Answer
  • wispolkboy
    wispolkboy Posts: 149
    Answer ✓
    Faustin wrote: »
    I had a pair of early Polk 4's with the Peerless tweeters several years ago. Mine just had piece of egg crate foam wedged behind the 6 1/2 drivers. It was falling apart. I ended up using some polyfill in each speaker and left out the foam.
    Thanks..
    I think that is what I will probably end up doing....
Answers
    F1nut Posts: 49,806
    Look on the inside cabinet walls for traces of the glue/foam. That's where it was.
  • wispolkboy
    Thanks for your reply! I only see glue where the cabinet was glued...
  • wispolkboy
  • Gardenstater
    Gardenstater Posts: 4,189
    edited August 2020
    In my 7B's the polyester fill was rolled or fan folded over itself and stuffed up behind the midbass driver and the tweeter. No glue whatsoever. Don't know about the 4's. Egg crate?? Was that something that Polk used or a previous owner put in there?
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • wispolkboy
    I have 2 sets, both from '82ish
    Different original owners.... Both had the eggcrate foam....so I think polk did that... There is the polo-fill down on the bottom of both sets
  • wispolkboy
    And thank you for the help!
    F1nut Posts: 49,806
    edited August 2020
    Polk used glued in place acoustic foam in the Monitor 11 under one mid-driver to reduce the bass frequencies from getting to the PR.
    So, I missed that your speakers are the considerably smaller Monitor 4, which I am not familiar with at all. I have to wonder why they would have used acoustic foam along with poly fill in the 4. Anyway, I wonder if it was placed above the mid-driver.
    Here's the only interior pic I found, which shows only poly fill and only up high.
    Post edited by F1nut on
  • wispolkboy
    Thanks so much for the picture...
    I will insert the polyfil as it looks in your picture in one speaker and some new foam in the back of the other and compair the sound of each....
  • wispolkboy
    Is the photo of that cabinet a monitor 4 from the late '80s? Mine have the peerless tweeters with the hole in it...
  • Faustin
    Faustin Posts: 1,149
  • wispolkboy
    edited August 2020
    Thanks everyone
  • dromunds
    dromunds Posts: 9,984
    Wispolkboy, where you located?
  • wispolkboy
    dromunds wrote: »
    I am in oak Creek WI
