Monitor 4 eggcrate/batting placement
wispolkboy
I went to epoxy my drivers and the eggcrate was disintegrated... So exactly where should I place the new eggcrate foam and batting?
M7's 1982 Peerless tweeters
M5's X2 (1981 Peerless tweeters, 1988 with upgraded tweeters)
M4's X2 both with Peerless tweeters
M5Jr with SL1500 (in the garage, they sound great)
M4.6 series2 X2 with upgraded tweeters
SDA 2 with upgraded tweeters
Best Answer
I had a pair of early Polk 4's with the Peerless tweeters several years ago. Mine just had piece of egg crate foam wedged behind the 6 1/2 drivers. It was falling apart. I ended up using some polyfill in each speaker and left out the foam.
Thanks..
I think that is what I will probably end up doing....M7's 1982 Peerless tweeters
Answers
Look on the inside cabinet walls for traces of the glue/foam. That's where it was.Political Correctness'.........defined
President of Club Polk -
Thanks for your reply! I only see glue where the cabinet was glued...M7's 1982 Peerless tweeters
SDA 2 with upgraded tweeters -
In my 7B's the polyester fill was rolled or fan folded over itself and stuffed up behind the midbass driver and the tweeter. No glue whatsoever. Don't know about the 4's. Egg crate?? Was that something that Polk used or a previous owner put in there?George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
I have 2 sets, both from '82ish
Different original owners.... Both had the eggcrate foam....so I think polk did that... There is the polo-fill down on the bottom of both setsM7's 1982 Peerless tweeters
Gardenstater wrote: »In my 7B's the polyester fill was rolled or fan folded over itself and stuffed up behind the midbass driver and the tweeter. No glue whatsoever. Don't know about the 4's. Egg crate?? Was that something that Polk used or a previous owner put in there?
And thank you for the help!M7's 1982 Peerless tweeters
Polk used glued in place acoustic foam in the Monitor 11 under one mid-driver to reduce the bass frequencies from getting to the PR.
So, I missed that your speakers are the considerably smaller Monitor 4, which I am not familiar with at all. I have to wonder why they would have used acoustic foam along with poly fill in the 4. Anyway, I wonder if it was placed above the mid-driver.
Here's the only interior pic I found, which shows only poly fill and only up high.
Post edited by F1nut onPolitical Correctness'.........defined
Thanks so much for the picture...
I will insert the polyfil as it looks in your picture in one speaker and some new foam in the back of the other and compair the sound of each....M7's 1982 Peerless tweeters
Is the photo of that cabinet a monitor 4 from the late '80s? Mine have the peerless tweeters with the hole in it...M7's 1982 Peerless tweeters
Thanks everyoneM7's 1982 Peerless tweeters
Wispolkboy, where you located?
