Speaker wires
Jdog
Should you use the same length speaker wires for L & R channels?
Do not have to.
I would, otherwise the signal from one speaker will get there ten quadrillionths of a second faster than the other, and it will throw the entire presentation out of balance.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »I would, otherwise the signal from one speaker will get there ten quadrillionths of a second faster than the other, and it will throw the entire presentation out of balance.
Just move your head 2mm to the side.Gustard X26 Pro DAC
if you ever want to resale them.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156
