Speaker wires
Should you use the same length speaker wires for L & R channels?
    pitdogg2 Posts: 27,545
    Do not have to.
    nooshinjohn Posts: 26,061
    I would, otherwise the signal from one speaker will get there ten quadrillionths of a second faster than the other, and it will throw the entire presentation out of balance.
    audioluvr Posts: 6,010
    Just move your head 2mm to the side.
  • marvda1
    marvda1 Posts: 4,964
    if you ever want to resale them.
    Puritan PSM156
