Test
Test
Lumin X1 file player
Sony XA-5400ES SACD
Pass XP-22 pre, X600.5 amps
Magico S5 MKII Mcast Rose speakers, SPOD spikes
Sony XA-5400ES SACD
Sony XA-5400ES SACD
(Your voice also increases in pitch the lower you go.)
Belles 350A Reference modded with Mundorf Supreme caps
Polk SDA 1C's modded
There is about a 5% genetic difference between apes and men …but that difference is the difference between throwing your own poo when you are annoyed …and Einstein, Shakespeare and Miss January.
by Dr. Sardonicus
I was testing how to create a quote in a Private Message thread, since for some reason Vanilla doesn’t allow quotes there. For example.
Sony XA-5400ES SACD
Sure it does, you can quote a thread and copy it -- but it will take the hyperlinks, too, which may or may not be advisable
Fixed
Doesn’t appear Vanilla let’s you quote a PM.
Sony XA-5400ES SACD
For those following along, manually quoting is like this: And you end up with this: All software engineer style
Oh. Yes. That.
Yup. Do it all the time.
Sorry, misunderstood.
BBCode (or HTML) is (are) cool.
Also a test...
It seemed to work, but Bud will have to tell me if the outcome in a DM was as intended on his end (as shown above, that is).
There is still no actual quote button in a PM, so you can add quotes, but you have to do it manually, such as copying the quote tags, or adding them yourself, and inserting the desired quote.
[ “quote” ] add your text here, and don’t use the “ ” as I just did[/quote]
test
<center><img src="https://i.imgur.com/PzqFTMx.png"></center>
<center> </center>
<center>Screenshouts:</center>
<center><img src="https://i.imgur.com/sJN0c24.png"></center>
<center> </center>
<center><img src="https://i.imgur.com/BflGAV7.png"></center>
<center><img src="https://i.imgur.com/CTuVEOJ.png"></center>
<center> </center>
<center><img src="https://i.imgur.com/DXmgyND.png"></center>
<center><img src="https://i.imgur.com/Wkk4BaA.png"></center>
<center><img src="https://i.imgur.com/ErWCcM5.png"></center>
<center><img src="https://i.imgur.com/BL1mMBl.png"></center>
<center>Video in action:</center>
<center><b><size>7]<a href=
<center><size>6]<b>Supported Windows Versions: Windows 10: 1903, 1909, 2004, 20H2.</b></size></center>
<center><font color=#fff0f5><size>4]<b>We're giving away a few daily keys for vouches, join my discord for more info. Please do not make duplicate discord accounts in order to receive keys. </b></size></font></center>
<center><font color=#fff0f5><size>4]<b>Thank you for your understanding.</b></size></font></center>
<center><b><size>8]<font color=#ccff33>SMALL</font><font color=#ff00cc>WORLD</font></size></b></center>
<center><i><b><size>8]<size>7]<font color=#faebd7>P</font><font color=#ff0066>remium </font><font color=#f0fff0>G</font><font color=#ff0066>ame </font><font color=#e6e6fa>C</font><font color=#ff0066>heats</font></size></size></b></i></center><font color=#dda0dd><size>6]<b><b><a href=https://discord.gg/EhrVj6sd4C>https://discord.gg/EhrVj6sd4C</a></b></b></size></font>
BBCode is generally better behaved on this here forum...
BBCode is generally better behaved on this here forum than HTML... (FWIW)
or, just "attach image"
For example, here's a CAT scan of a loudspeaker under assessement in the lab.
Wait, check that.
I think I was told there wouldn't be any math.
EPIC.
fail.
