Optimal Speaker Wire Gauge
2
Answers
    audioluvr Posts: 5,905
    Wireworld Silver Eclipse.
    Nordost Frey 2
    Audioquest Silver Jupiter
  • BlueFox
    BlueFox Posts: 15,251
    Of course you can do better. Start with Shunyata's entry level speaker cable.
    https://shunyata.com/products/audio-cables/venom-series-audio-cables/venom-sp/
    https://shunyata.com/speaker-cables/
    F1nut Posts: 51,746
    edited August 2020
    That was crap cable then and now. Yes, you can do much better. Forget about the gauge.
    mhardy6647 Posts: 34,993
    F1nut:
    I think you should buy some real speaker cable.
    That *was* real speaker cable (Monster) circa 1995 and that's the point of my thread.
    and this was a real car in 1995.
    The world changes.
    I plan to replace this cable and I'm trying to at least replicate the gauge, as I'm pleased with the sound that I get, but while I'm at it, can I do better?
    I'd encourage you, in all seriousness, not to obsess about the gauge per se. Three (big) things matter about cable -- resistance, capacitance, and inductance. Beyond those three, there are more subtle differences related (perhaps!) to geometry, materials of construction, interconnect design, dielectrics, etc.
    Look at your amplifier power, the nature of your loudspeaker load (impedance and phase curves) and the run length for the wire. If you know your amplifier's output resistance ("damping factor"), you can also calculate the impact of a length of hypotherical cable of a given resistance on that, if you like. Chances are, anything beyond 16 gauge is overkill. Overkill is fine (this is America, after all), but focusing on cable cross-sectional area is like focusing on (only) horsepower when buying a new car. You can, but there's other stuff in the package that's every bit as important in the real world.
  • Gardenstater
    Gardenstater Posts: 4,779
    When I went from 6ft long 16 gauge lamp cord to 13 gauge Litz of regular copper I heard a tremendous improvement in Bass and overall clarity. Then when I went to 5ft 14 gauge 4N copper Ribbon configuration cables with a 0.003" dielectric spacing the improvement was huge over the Litz. Highs became crystalline and bass maintained it's punch and the transient response became much faster. That's my story and I'm stickin' to it.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • OK, I think I've given this speaker cable thing enough air. Think I'm gonna go with 12 feet of 10 ga Mark Grant cables. Thanks for all the help.
    And F1nut, maybe you had different setups when you compared the Polk SDA-2B's as better than the 1C's. Got the 1C's this week and they're vastly superior to the 2B's. A wraparound wall of sound with the 1C's versus an occasional sliver of outside-the-speakers mid-range frequencies with the 2B's. Bigger bass.
    Just sayin' ...
    Polk SDA-1Cs with RD0194-1 upgrade tweeters, SoniCaps, Clarity PX, Gimpod boards, Cardas BPs, Erse inductors, Canare 4S11 IC; Michi P5; Yamaha M-80; Yamaha CD-S1000; Oppo BDP-95; Sony UBP-X800M2; EverSolo DMP-A6; Topping DX-7 Pro +; Technics SL-1400 with Ortofon 2M Bronze PnP; PS Audio Dectet; AudioQuest Red River ICs; AudioQuest NRG-Z3 PCs; RapcoHorizon High Def High 413-Strand 10AWG Speaker Cable; Auralex Isolation Pads
    F1nut Posts: 51,746
    edited August 2020
    Then something seriously isn't right with your 2B's. One of your drivers is likely wired incorrectly as that will kill the soundstage as well as the bass response.
    I and others have compared them with the same gear in the same room and also at different places with different gear and different people, all with the same conclusion. The 2B is the better balanced and therefore better sounding speaker.
    Bigger bass? I guess if you like an over preponderance of bloated mid bass.
  • Gardenstater
    edited August 2020
    What features made you choose those....description....details? Their site doesn't even seem to use the American Wire Gauge system. Are you in England?
    This one? https://www.markgrantcables.co.uk/uk/speaker-cables/van-damme-2-x-25mm-hi-fi-speaker-cable-up-lcofc-unterminated/
    I did the math and that is about a 13.2 gauge cable, and with all those fine strands (7 x 46) I don't think their claim that it minimizes skin effect holds any water because it isn't enough to have small diameter strands but they must be electrically insulated from one another. That's what Litz is all about.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    audioluvr wrote: »
    Yeah and I'm definitely not in the camp that believes more and finer strands is better because, even though the measurement freaks claim it makes no difference, I believe it smears the sound to have the signal crossing all those wire boundaries. That's why UPOCC Ohno wire sounds better, very few grain boundaries for electrons to cross.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Clipdat Posts: 13,094
    Don't cross the streams!
  • Ah, where to start?
    F1nut: The 1c's sound better on my system. Perhaps the one you A/B'd your pair with wasn't the same unit/make/wpc as mine. The results you got were specific to the systems used. The bass comments were unnecessary. I'm not a headbanger.
    Gardenstater: 2.5mm is 10AWG. You can actually look this stuff up. I've seen that if I ask 10 people their preference on speaker cable, I get about 12 answers. So I'll start with something, A/B it against what I've got, and start the journey to finding out what's the best for me like all of you did. And yep, those cables are in the UK.
    Fedex.
    audioluvr: It's all fancy lamp cord. We pay all this $$ and obsess over all these details to get marginal gains that are significant to us.
    Now on to something else ....
    F1nut Posts: 51,746
    It's got nothing with being a headbanger. The fact that you said that tells me you have no idea what an over preponderance of bloated mid bass actually is. If you bothered to figure out what is wrong with your 2B's you might just discover what many of us with over 30 years of SDA experience know.
  • Gardenstater
    edited August 2020
    Ah, where to start?
    Fedex.
    I mistakenly thought that you wanted to learn. 2.5mm is 10 gauge ONLY IF we are talking about solid core wire. The mfg. you are going with that has the glorified lamp cord (it does look nice) specifically states that the construction is:
    Conductor stranding – 7 x (46 x 0.10mm)
    Now if you calculate the area of a 0.10mm dia. wire (Pi times diameter squared divided by 4) and multiply it by 46 and then by 7 you get that it is more like 13.2 gauge, from this chart:
    https://www.powerstream.com/Wire_Size.htm
    Most of us enjoy this hobby by doing our own experimentation and seeing the incremental improvements, so you'll be fine. You'll just spend a LOT more money in the end. :D
    PS: The really frustrating thing about this is that you have no clue still what your original cable's AWG (because you didn't follow my advice on how to measure) is and your whole premise was that you wanted to duplicate with new glorified lamp cord (my words) but you don't even know if you will be doing that. SMH
    Post edited by Gardenstater on
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    For better or worse, it's not all "fancy lamp cord."
    Some of the wires sold for hifi use are almost terrifyingly exotic in design, sometimes making them interesting, reactive loads for amplifiers all by themselves (even before they're connected to a loudspeaker).
    F1nut Posts: 51,746
    Definitely not lamp cord.
  • DillyD
    DillyD Posts: 3
  • DillyD
    DillyD Posts: 3
    edited August 2020
    I'm having trouble hooking up these speakers to my record player, how do I so it?
  • DillyD
    DillyD Posts: 3
    How do hook these together?
    msg Posts: 10,452
    Do you have a receiver with a phono/turntable input?
    Record Player >> Receiver >> Left and Right Speaker Cables out to speakers. You need terminal nuts on those speaker terminals, or banana plugs.
    pitdogg2 Posts: 27,029
    You're flipping joking right?
    You cannot be that audio dumb.
    txcoastal1 Posts: 13,511
    DillyD wrote: »
    Don't knock it till you try it. Someone here smarter than me once said " People who don't know, don't know they don't know. Ya know?"
  • Gardenstater
    edited August 2020
    If you don't want to rush in and pay the big $$'s or even moderate $'s for some mfg's offering that is recommended by knowledgeable and experienced folks here, why not start down the path of educating yourself and DIYing some cables yourself that might surprise lots of people as far as how well they perform? You can make a damn good one from some CAT5e cable. It will be whatever gauge you want it to be so make it the same gauge and length as your lamp cord for A/B ing the two, ETP electrolytic tough pitch copper which is probably what is in your lamp cord or slightly worse if you really do have .9995 copper, and most importantly will be Litz as well as low inductance due to the twisted signal pairs! Make it the same gauge as your glorified lamp cord and then get back to us. That's what I did for my first step away from lamp cord. Here's where I began to learn and got the construction details.
    https://www.tnt-audio.com/clinica/tweaks.html
    https://www.tnt-audio.com/clinica/diycables.html
    https://www.tnt-audio.com/clinica/ffrc_e.html (<<13 gauge)
    https://www.tnt-audio.com/clinica/triple_t_e.html (<<this one should be 10 gauge)
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Thanks. I'll add it to the list.
  • fish357
    fish357 Posts: 304
    edited September 2020
    I would offer that, using the formulas below, one should be able to figure out how much power- Jules in this instance- a given gauge and length can carry before falling on its face (ie resistance).
    If you put a gallon of water into a large funnel, it’s going to come out a lot more slowly than it went in.
    Maybe this is helpful, maybe not.
    I realize the application is a little different (I spent 7 years doing 12 volt stuff for cops), but I believe the concept is the same. In this case you’re just talking in terms of impedance- alternating current, versus resistance- direct current.
    I’m probably saying stuff most of you already know.
    the units of power are Watts.
    the units of energy are Joules.
    the units of force are Newtons.
    https://physics.nist.gov/cuu/Units/units.html
    1 Watt = 1 Joule/second = 1 (m^2-kg)/sec^3
    1 Joule = 1 Newton-meter = 1 (m^2-kg)/sec^2
    1 Newton = 1 (kg-m)/sec^2
    Yes but how do your joules sound? :D
  • BlueFox
    My next Shunyata speaker cables.
  • fish357
    fish357 Posts: 304
    audioluvr wrote: »
    You’d have to ask my girlfriend, I never get close enough to hear.
