Front port tube on brand new RTiA9 arrived completely broken off.
SoundSolution
Where did you order them from?
Brand new should be easily dealt with. Either the carrier or the vendor (dealer) should be liable for the damage. Probably the former, but I'd start with the dealer (were it me) -- a good one would, I'd expect, either help the victim OP out or give good advice to him/her/them.
Best Buy. I'm passing on unboxing the other one & sending them both back. Both boxes arrived fairly beaten up. -
SoundSolution wrote: »
Yep best outcome -
Seems like a sound solution to your problem
In my experience it would just slide back on and is just glued in place- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Probably a good idea to send back.
Who knows what else is damaged internally.
Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
