Front port tube on brand new RTiA9 arrived completely broken off.
    Clipdat Posts: 13,106
    Where did you order them from?
    mhardy6647 Posts: 35,562
    Brand new should be easily dealt with. Either the carrier or the vendor (dealer) should be liable for the damage. Probably the former, but I'd start with the dealer (were it me) -- a good one would, I'd expect, either help the victim OP out or give good advice to him/her/them.
  • SoundSolution
    Clipdat wrote: »
    Best Buy. I'm passing on unboxing the other one & sending them both back. Both boxes arrived fairly beaten up.
    pitdogg2 Posts: 27,914
    Clipdat wrote: »
    Yep best outcome
    Clipdat wrote: »
    Sounds good.
    VR3 Posts: 29,759
    Seems like a sound solution to your problem
    In my experience it would just slide back on and is just glued in place
  • Joey_V
    Joey_V Posts: 8,606
    Probably a good idea to send back.
    Who knows what else is damaged internally.
