All my speakers 6.5" dome cracked!
RTiA7 (pair) and CSi A6 are both bought in mid of 2013 in Singapore.
Having spare time in this pandemic period, I decided to do a maintenance to all my speakers.
First grill removed, I was shocked. Dome of 6.5" drivers is cracked.
Opened the 2nd, cracked.
The third, cracked.
I knew they are out of 5-year warranty, what can I do? Buy all again?
How can I get trust from Polk Audio?
    Clipdat Posts: 12,607
    Why is there a doily on top of your Emotiva amplifier?
  • Nim
    Nim Posts: 13
    Clipdat wrote: »
    May protect from dust?
    Anyway, my wife likes it.
  • Gardenstater
    Gardenstater Posts: 4,186
    I think dust caps are mostly cosmetic, but that certainly does suck.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    VR3 Posts: 28,042
    Looks like the dust caps, would just apply some sealant if it bothered you and keep on rocking!
    msg Posts: 9,461
    edited August 2020
    Are they still soft?
    Just checked the dust caps on the mids on a pair of 2013 refurb RTi10s and they're soft and intact.
    What do you use to clean your speakers? Have those dust caps had any chemical cleaners or conditioners on them?
    Here's one of mine for comparison:
    (this is shot from about the 10 o'clock position)
  • Nim
    Nim Posts: 13
    edited August 2020
    msg wrote: »
    Thanks for reply.
    Yes, they are still quite soft.
    I can not remember I'd ever cleaned the drivers. I grilled them since the first day coming to my house.
    I cleaned them this morning after these lovely cracks discovered with a 3M multi-purpse cloth lightly wet by dechlorinated tap water.
    My surround speakers are J** bought in 2003 which were used as main before PA introduced.
    Same way never cleaned, same room, after 17 years, J** like new, see below photo.
  • Nim
    Nim Posts: 13
    edited August 2020
    VR3 wrote: »
    Thanks. I will give it a try.
    I can hear some "SSS" sound from the cracked drivers. I'd noticed this sound but never took it seriously.
    Are the "SSS" sound and cracked dust cap related?
    Thanks.
    F1nut Posts: 49,802
    Got kids?
    pitdogg2 Posts: 24,579
    Well see that there is the problem. If you would have just boiled them....
  • Nim
    Nim Posts: 13
    edited August 2020
    Got kids?
    My kids are born between the above mentioned speakers.
    I have confidence it's not done by their itchy hands,
    1)They don't know the grille is removable
    2)They are cracks not dent.
    B)B)B)
  • Nim
    Nim Posts: 13
    edited August 2020
    Deleted for the repeated post
    F1nut Posts: 49,802
    Nim wrote: »
    Got kids?
    B)B)B)
    I'm very aware they are cracked not dented. The reason I asked if you had kids is the possibility they turned the volume up way too high while you weren't around resulting in the damage. Just speculation though.
    You have very high humidity in Singapore, so I wonder if that is a factor?
    audioluvr Posts: 5,437
    edited August 2020
    Pooh did it?
    VR3 Posts: 28,042
    My mind went to humidity but in the other direction, excessive removal of moisture to where it would dry out the material
    F1nut Posts: 49,802
    Good point. I'd say either is a possibility.
  • Gardenstater
    Going forward, you need a web camera on your speakers uploading to the cloud.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    Nim wrote: »
    Clipdat wrote: »
    The ill-placed doily caused the amp to go into thermal overload due to lack of proper ventilation, sending clipped signals to the speakers and overheating the voice coils and motor structure, leading to the cracked dust caps. Boom. Case closed.
  • Nim
    Nim Posts: 13
    edited August 2020
    Clipdat wrote: »
    Nim wrote: »
    Clipdat wrote: »
    Hold on, don't close first.
    Kindly explain what happened to the centre speaker who is connecting to receiver and nothing to do with the ill emotiva.
    By the way, doily is only for dust protection. It would be removed when the machine is on.
    I can understand putting a protective cloth over the amp when not in use but it must be off while using or it will not allow proper ventilation to dissipate heat.
  • Emlyn
    Emlyn Posts: 4,372
    Any possibility of a power surge or lightning strike over the years? I know Singapore gets lots of storms.
    Other than that, the only thing I can think of since it is physical damage is the drivers were pushed too hard by someone cranking the volume too high. Replacement drivers may be available.
  • VSAT88
    VSAT88 Posts: 1,227
    I know you have not asked this but here goes. Any company that sells speaker re cone / foam surround kits will almost definitely sell dust covers. Not the same exact one but one that will work. If you are pretty good with a razor blade knife and some Aleene's glue for only a few bucks invested you could fix those speakers up, all of them with brand new dust covers that would last and last. Just a thought.
  • Nim
    Nim Posts: 13
    edited May 2021
    I applied some silicone to the cracked dust cap as adviced by someone last year.
    It is falling apart now!
    And many nuts are rust-brown.
    I threw out the A6 center already, cracked and rusted.
    Is it normal like this in place like Singapore?
    silicone is a no no.
    Unless the bolts are stainless they will rust from the humidity in the air. Mine have done it as well.
    if you live close to the ocean, I've heard others who have had problems with the salt spray corroding things.
    VR3 Posts: 28,042
    Well that escalated quickly
  • Nim
    Nim Posts: 13
    edited May 2021
    Thanks for your reply.
    I'm living in Singapore and it's an island standing in Ocean. As far as I'm concerned, I didn't notice anything actually get rusted easier than anywhere else since it's just meters away from the continent and the frequent pouring rain may reduce the salt corroding a lot. Of course, it introduces high humidity together.
    My 18yo JBL BOOKSHELF, same environment as PA just 2x older, are going strong. No full range rusting, no cracks, no aging. It looks like new!
    I do think their (JBL) engineers knows material they used very well, that is from many years speakers making.
    I like PA, sound is good.
  • gp4jesus
    gp4jesus Posts: 1,969
    the RTi A series screws securing the drivers are aluminum.
    That said, make certain you have the correct size Allen wrench. It’s an UNcommon size; a difficult-to-obtain tip for your cordless screwdriver. It’s very easy to damage the screws.
    Use the wrench to do loosen and the final tightening by hand. It’s easy to strip the cabinet.
    Good luck on the repair. Tony
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
    Those screws certainly do not appear to be aluminum they appear to be rusted fairly well, which if they were aluminum the "rust" would not be that color.
  • Nim
    Nim Posts: 13
    gp4jesus wrote: »
    I have to disagree about the screw material.
    That brown is rust-brown or corrision from steel/iron not aluminum.
    Thanks for your ideas about fix.
  • Nim
    Nim Posts: 13
    The more i look into my case, the more I realize RTi R7 (or the series) is the compromised product between performance and cost.
    Do these cost-saving design really save a lot? To me, they are just few dollars thing and will be big different.
    A simple comparison between P/A RTi A7 and JBL E30
  • gp4jesus
    Nim wrote: »
    I am sorry. I bought mine in 2008. The first time I opened them I discovered the silvery colored screws seemed very soft. I mistakenly believed they were aluminum. They are, obviously, a of VERY soft iron based material.
