All my speakers 6.5" dome cracked!
Simply Speakers sells dustcaps. I would assume that other speaker companies sell them also. Replace the dustcaps if it bothers you. Otherwise, just leave the grill coveres on.Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ (2x) Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2
Teac R-919X ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Winter Residence 2.1 (laptop system):
Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
classic carl wrote: »Simply Speakers sells dustcaps. I would assume that other speaker companies sell them also. Replace the dustcaps if it bothers you. Otherwise, just leave the grill coveres on.This^^^
But the shipping may be pricey to ship to Asia. Someone over there should also have some you could glue on.
Thanks.
Step 1: New dustcaps.
I purchased the dustcaps from online shop. It looks not so bad,
Above: new coming
Step 2: remove the broken, cracked ones
Above: after removal.
It's easier than I thought. It's quite direct.
Step 3: Glue the new one on
Above: that's it after fix.
Bonus:
Above: a close look of the broken dustcap. White salt-alike things on the back side.
The sound is 100000x better now
I have been seeing this more and more With China making most of the metal hardware, Bolts, screws etc. over the last 20yrs.
Aluminum, grade 8 steel, Any kind of metal gear these days. I have noticed these same defects in all metals used in all fields, Auto, Cycle whatever field or industry's.
The metals are not the same quality or even close to correct blends, like back when most of the steel was made in the USA. It really is sad what they will allow to be called Aluminum, grade 8 steel that comes out of China, it gets terrifying when it is used in brake parts or any critical parts. All you can do is replace the bolts and be glad it is a speaker screw and not somewhere it could get somebody hurt.
Good job on those dust caps, they look like new again.... -
I feel that way too.
I will change the bolts/screws if I can find the replacement. Very ugly. -
I point you to Jesse’s (F1nut) work in this thread as he deserves all the credit for the execution...
http://forum.polkaudio.com/discussion/159998/rtia7-and-csia6-crossover-upgrades-a-slightly-different-approach/www.crgproducts.com
...not the easiest solution but it worked for me too. I have used h-nuts to secure my LFE’s power amp.
Side note: I used a file to trim the H-nuts and limited the upgrade to mids and woofers.Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Thanks.
Above: new coming
Bonus:
What is the size of the dust cap you bought for your center and floorstanders? I had the same situation as well.
