Monitor 70 power handling
Hello. I have an emotiva 275 watts RMS per channel (@ 8 ohm load) amp. I put my oscope on the output on my amp and played 1 khz tone. I've witnessed that this amp starts to clip at about 55v (378watts correct?) but I noticed it has a limiter that kicks in and keeps the voltage below 55v if I continue to turn up the volume knob. so I know im working with a clean unclipped signal.
Ok so my question is how well will the Monitor 70 series II handle the power? I know a lot will say "listen for the symptoms of an over driven speaker" . Im not good at that. I might crank up the volume and walk away. my wife may do the same and she is def not going listen for signs. I would rather more of a black and white answer or at least a good reference.
So someone please clarify the *continuous * *many hours in a jam session* power handling capabilities. I see the vague specs the Monitor 70 says 20-275 watts. Does that mean I can
keep my power levels to 275 watts and not worry about cooking the speakers ? Or does it mean I might only get away with a few mins of 275watts of power and then burn out ? or should I choose another speaker if Im looking for that kind of power ?
Thanks. Steve
Thanks. Steve
When the speaker starts clipping and/or distorting then it has reached its limit with the amp. Generally, the more power the amp has the louder the speakers can play before distorting. However, at some point all speakers reach their limit.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I understand that. What I am asking is what is the safe continuous limit ? -
This depends on the source level, preamp, and the music being played but in general I never go above noon on the volume dial. Really even 11 o'clock.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Sounds like you'd be better off with a few of these: https://www.pssl.com/products/qsc-k12-2-12-inch-2-way-2000w-powered-speaker
"But again, too long, too loud = hearing damage." That too
So is there "a close to a black and white" answer as to what constant power handling will start to melt the coil over a period of several hours ? I can already smell my monitor 30s burning.
Even if someone gave you an exact specification how would that help?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
For starters you'll never keep your amp pumping out a continuous 275 wpc or any continuous wattage amount because music is dynamic. Most of the time, even at loud levels, an amp is loafing along at a very low wpc except when there are transients and/or heavy bass tracks, but still the amp output is not continuous.
President of Club Polk -
Unless you plan on listening to a 1kHz test tone your finding/conclusion is absolutely worthless.Political Correctness'.........defined
I could measure the output and turn it below -
yes I understand music is dynamic but there still can still be reference. audio signal still have a floor, a ceiling, and an average of voltage
edit: that's why use the term RMS … aka the average
There is no exact specification because music is dynamic. Read that until it sinks in.Political Correctness'.........defined
Just consider 11 o'clock on the volume dial to be max and you should be good, assuming flat tone controls. 👍afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
that doesn't mean anything. there are all kind of variables between volume knobs. -
Yes there is... its called RMS. -
Did you order the powered QSC speakers yet?
It's a general safe ballpark that doesn't involve wasting your time figuring out how to run your entry level speakers at the exact bleeding edge of being cooked.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
LOL.....suuuuuuurePolitical Correctness'.........defined
Honey, it's simple. I understand you aren't going to listen for the soundstage to collapse so all you need to do instead is measure the output of the amp with this here oscilloscope and do a little math. It's the price we have to pay to listen as loud as possible without frying voice coils.
Your wife is going to be stoked.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
I couldn't find a picture anywhere but I remember Beavis had his own pro speakers. They were redbadged Peavey's named Beavey.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
I did measure it. 2 dmms, 2 ch scope with worn out pots, lol totally not a problem.
I don't want to buy the speakers and find out they barley can handle 100 watts. I bought a 275 watt amp, so I want to make use of the damn thing.. not have to worry about "goin' past 11 oclock on the knob"
its like buying a sports car and never getting passed 35 mph.
Sincerely,
Honey
Even when I had 1.2s hooked up to a 350 watt amp I didn't go above 11-12 o'clock.
Maybe consider getting some ultra efficient big floor standing Klipschs. My uncle had a pair with a passive radiator on the back of the cab growing up, don't recall model, that would melt your ear drums on a 100 watt amp.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
"What we've got here is failure to communicate. Some men you just can't reach."Political Correctness'.........defined
I feel like my post above was skipped...was it too wordy?
I will summarize..."Heat is bad."
Yep, I agree and I understand."Continuous heat is worse."
Yep, I agree and I understand."The more power you provide, the more thermal load needs to be dissipated. And with the budget oriented components in your speakers, that thermal threshold is much lower."
Yep, I agree and I understand."You have already stated that you have gone beyond the point of safety to the point of thermal failure. You have already caused damage."
Yes. That is correct. On the Monitor 30s I was using. Nothing to do with Monitor 70s"If you aren't capable of listening at normal or moderate levels, the only valid advice will be, buy speakers meant to do what you want to do. The Monitor 70s are not those speakers."
Are you sure ? Because Polk says yes, 275watts RMS no problem.(What I am assuming based on your responses is that your goal is a constant loud output. Buy speakers that are designed for that...PA speakers...pro amps...etc.)
Which model and brand would you suggest ? Beavey ? -
Why bother to ask a question if you are going to ignore the advice? Just go blow up your speakers and be done with it already.
Ok guys, I really appreciate your help. I am now understand that home theater speakers are different than PA speakers. I thought I would have a cross between the two kinds. I do also want to use them for home theater. I do want them to sound nice. I watch a ton of movies. I also want them to look nice. and I also want to be able to rock out with my c0@k out like beavis and butthead.
In conclusion I will buy Monitor 70s and back off when they get to hot. -
To be fair, Peavey makes very good speakers for live sound and DJ use, speaking from fist-hand experience. -
why not ? To me, It would be at least a starting reference. and isn't that same exact process used to set gains ?
By that time, it's too late and you'll fry something. I think your mistake is thinking that an amp is used for loudness....it isn't.
Monitor 70's is a good all around speaker for movies and music, but it's at the lower end of the scale in comparison to Polks other offerings. It's an easy to drive speaker too which doesn't require gobbs of power. If you like loud, something like a Klipsch speaker or PA speaker may be more up your alley. They are made to play loud, without toasting things.
