Monitor 70 power handling
pyro5ive
pyro5ive Posts: 12
Hello. I have an emotiva 275 watts RMS per channel (@ 8 ohm load) amp. I put my oscope on the output on my amp and played 1 khz tone. I've witnessed that this amp starts to clip at about 55v (378watts correct?) but I noticed it has a limiter that kicks in and keeps the voltage below 55v if I continue to turn up the volume knob. so I know im working with a clean unclipped signal.
Ok so my question is how well will the Monitor 70 series II handle the power? I know a lot will say "listen for the symptoms of an over driven speaker" . Im not good at that. I might crank up the volume and walk away. my wife may do the same and she is def not going listen for signs. I would rather more of a black and white answer or at least a good reference.
So someone please clarify the *continuous * *many hours in a jam session* power handling capabilities. I see the vague specs the Monitor 70 says 20-275 watts. Does that mean I can
keep my power levels to 275 watts and not worry about cooking the speakers ? Or does it mean I might only get away with a few mins of 275watts of power and then burn out ? or should I choose another speaker if Im looking for that kind of power ?
Thanks. Steve
  • BlueFox
    BlueFox Posts: 15,251
    When the speaker starts clipping and/or distorting then it has reached its limit with the amp. Generally, the more power the amp has the louder the speakers can play before distorting. However, at some point all speakers reach their limit.
  • pyro5ive
    pyro5ive Posts: 12
    BlueFox wrote: »
    I understand that. What I am asking is what is the safe continuous limit ?
  • Nightfall
    Nightfall Posts: 10,084
    This depends on the source level, preamp, and the music being played but in general I never go above noon on the volume dial. Really even 11 o'clock.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • afterburnt
    afterburnt Posts: 7,892
    "But again, too long, too loud = hearing damage." That too
  • pyro5ive
    pyro5ive Posts: 12
    So is there "a close to a black and white" answer as to what constant power handling will start to melt the coil over a period of several hours ? I can already smell my monitor 30s burning.
  • Nightfall
    Even if someone gave you an exact specification how would that help?
    afterburnt wrote: »
    F1nut Posts: 51,682
    For starters you'll never keep your amp pumping out a continuous 275 wpc or any continuous wattage amount because music is dynamic. Most of the time, even at loud levels, an amp is loafing along at a very low wpc except when there are transients and/or heavy bass tracks, but still the amp output is not continuous.
    F1nut Posts: 51,682
    Unless you plan on listening to a 1kHz test tone your finding/conclusion is absolutely worthless.
  • pyro5ive
    pyro5ive Posts: 12
    Nightfall wrote: »
    I could measure the output and turn it below
  • pyro5ive
    pyro5ive Posts: 12
    edited July 2020
    yes I understand music is dynamic but there still can still be reference. audio signal still have a floor, a ceiling, and an average of voltage
    edit: that's why use the term RMS … aka the average
    F1nut Posts: 51,682
    pyro5ive wrote: »
    Nightfall wrote: »
    There is no exact specification because music is dynamic. Read that until it sinks in.
  • Nightfall
    Just consider 11 o'clock on the volume dial to be max and you should be good, assuming flat tone controls. 👍
    afterburnt wrote: »
  • pyro5ive
    pyro5ive Posts: 12
    Nightfall wrote: »
    that doesn't mean anything. there are all kind of variables between volume knobs.
  • pyro5ive
    pyro5ive Posts: 12
    pyro5ive wrote: »
    Nightfall wrote: »
    Yes there is... its called RMS.
    Clipdat Posts: 13,087
    Did you order the powered QSC speakers yet?
  • Nightfall
    pyro5ive wrote: »
    Nightfall wrote: »
    It's a general safe ballpark that doesn't involve wasting your time figuring out how to run your entry level speakers at the exact bleeding edge of being cooked.
    afterburnt wrote: »
    F1nut Posts: 51,682
    pyro5ive wrote: »
    pyro5ive wrote: »
    Nightfall wrote: »
    LOL.....suuuuuuure
  • Nightfall
    edited July 2020
    Honey, it's simple. I understand you aren't going to listen for the soundstage to collapse so all you need to do instead is measure the output of the amp with this here oscilloscope and do a little math. It's the price we have to pay to listen as loud as possible without frying voice coils.
    Your wife is going to be stoked.
    afterburnt wrote: »
  • Nightfall
    I couldn't find a picture anywhere but I remember Beavis had his own pro speakers. They were redbadged Peavey's named Beavey.
    afterburnt wrote: »
  • pyro5ive
    pyro5ive Posts: 12
    Nightfall wrote: »
    I did measure it. 2 dmms, 2 ch scope with worn out pots, lol totally not a problem.
    I don't want to buy the speakers and find out they barley can handle 100 watts. I bought a 275 watt amp, so I want to make use of the damn thing.. not have to worry about "goin' past 11 oclock on the knob"
    its like buying a sports car and never getting passed 35 mph.
    Sincerely,
    Honey
  • Nightfall
    Even when I had 1.2s hooked up to a 350 watt amp I didn't go above 11-12 o'clock.
    Maybe consider getting some ultra efficient big floor standing Klipschs. My uncle had a pair with a passive radiator on the back of the cab growing up, don't recall model, that would melt your ear drums on a 100 watt amp.
    afterburnt wrote: »
    F1nut Posts: 51,682
    "What we've got here is failure to communicate. Some men you just can't reach."
  • pyro5ive
    pyro5ive Posts: 12
    ZLTFUL wrote: »
    I feel like my post above was skipped...was it too wordy?
    I will summarize...
    "Heat is bad."
    Yep, I agree and I understand.
    "Continuous heat is worse."
    "The more power you provide, the more thermal load needs to be dissipated. And with the budget oriented components in your speakers, that thermal threshold is much lower."
    "You have already stated that you have gone beyond the point of safety to the point of thermal failure. You have already caused damage."
    Yes. That is correct. On the Monitor 30s I was using. Nothing to do with Monitor 70s
    "If you aren't capable of listening at normal or moderate levels, the only valid advice will be, buy speakers meant to do what you want to do. The Monitor 70s are not those speakers."
    Are you sure ? Because Polk says yes, 275watts RMS no problem.
    (What I am assuming based on your responses is that your goal is a constant loud output. Buy speakers that are designed for that...PA speakers...pro amps...etc.)
    Which model and brand would you suggest ? Beavey ?
  • DaveHo
    DaveHo Posts: 3,582
    Why bother to ask a question if you are going to ignore the advice? Just go blow up your speakers and be done with it already.
  • pyro5ive
    pyro5ive Posts: 12
    Ok guys, I really appreciate your help. I am now understand that home theater speakers are different than PA speakers. I thought I would have a cross between the two kinds. I do also want to use them for home theater. I do want them to sound nice. I watch a ton of movies. I also want them to look nice. and I also want to be able to rock out with my c0@k out like beavis and butthead.
    In conclusion I will buy Monitor 70s and back off when they get to hot.
    Nightfall wrote: »
    To be fair, Peavey makes very good speakers for live sound and DJ use, speaking from fist-hand experience.
  • pyro5ive
    pyro5ive Posts: 12
    edited July 2020
    why not ? To me, It would be at least a starting reference. and isn't that same exact process used to set gains ?
  • pyro5ive
    pyro5ive Posts: 12
    edited July 2020
    tonyb Posts: 33,066
    pyro5ive wrote: »
    By that time, it's too late and you'll fry something. I think your mistake is thinking that an amp is used for loudness....it isn't.
    Monitor 70's is a good all around speaker for movies and music, but it's at the lower end of the scale in comparison to Polks other offerings. It's an easy to drive speaker too which doesn't require gobbs of power. If you like loud, something like a Klipsch speaker or PA speaker may be more up your alley. They are made to play loud, without toasting things.
