L800 and Compatibilty with External Amps
VXR8
VXR8 Posts: 291
G'day all,
Saw this on YouTube from Audioholics and around the 13 minute mark they say the L800s will not work for the SDA part with a differential or fully balanced external amp. Here is the link for the review:
https://youtu.be/6MLgmBm-LtE
Can anyone please confirm if this is the case?
Thanks in advance.
Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200
Best Answers
    F1nut Posts: 52,164
    Answer ✓
    The topology of a fully balanced amp doesn't make it a power amp no matter what. As to what it is about the current SDA speaker that makes it incompatible I can't tell you for sure, but it would have to do with the SDA circuit topology.
    I believe Polk included that info in the manual, but you can't see the manual until you buy the speakers.
    F1nut Posts: 52,164
    Answer ✓
    I stand corrected, the manual is available online and surprisingly does not mention anything about the incompatibility issue. They should correct that immediately.
  • marvda1
    marvda1 Posts: 4,965
    Answer ✓
    he explained it in the video.
    Puritan PSM156
    F1nut Posts: 52,164
    Answer ✓
    Yes
Answers
    F1nut Posts: 52,164
    Already common knowledge.
  • VXR8
    VXR8 Posts: 291
    edited June 2020
    So you can use a ‘normal’ external amp? That common knowledge should be printed in the owners manual too so people don’t fork out thousands on an external amp to find it won’t work. So can you please explain why balanced / differential amps won’t work with these speakers?
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • VXR8
    VXR8 Posts: 291
    Anyone have anything re why a balanced / differential amp doesn't work? Common knowledge doesn't explain why - logic says it's still a power amp no matter what, it's still powering the speakers so why won't it work?
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • VXR8
    VXR8 Posts: 291
    Thank you - so an unbalanced power amp will work with the SDA component of these speakers then?
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • mpitogo
    mpitogo Posts: 520
    edited June 2020
    @VXR8 the main point to consider is common ground and singled ended amplifier topology. The SDA channel gets its signal from the opposite channel and needs the full signal to perform optimally which is referenced to ground. With a balanced differential amplifier, the ground is floating, the red terminal provides a positive signal the black terminal provides a negative (opposite) signal and together provide the full signal peak to peak (+ and -). With a balanced differential SDA will only get half of the audio signal.
    When SDA first came out, I don't believe true balanced differential amplifiers where too common in the price segment they were in. Today for the modern L800, most folks will want to spend a complementary sum of money to power these current hungry speakers and balanced differential amps are more common in the price segment they are in.
    I agree totally there should be a warning on these speakers that amplifier selection matters, eg McIntosh (quad balanced), PS Audio (BHK), high end Marantz and Yamaha (eg PM-10, A-S3200) and monoblocks.
    Amps I believe would work are, Anthem, Emotiva, Parasound, Rotel.
    In my personal case I tried both my Marantz PM-10 and McIntosh MC452 but ultimately settled on a bi-amp setup with a common ground McIntosh integrated in full time passthru for the treble and SDA channel, while bass is powered by the Quad Balanced MC452.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
    mhardy6647 Posts: 35,389
    edited June 2020
    Y'all just be careful not to conflate balanced vs. "single-ended" (unbalanced) cabling/ component interfaces and balanced ("push pull") vs. single ended amplifier design topology, y'hear?
  • mpitogo
    mpitogo Posts: 520
    edited June 2020
    Yes true@mhardy6647 single-ended typically RCA vs balanced XLR/TRS for cabling/component interfaces, SDA doesn't care if the Line Level signal fed is either one, it only cares if the amplified output is balanced differential.
    pitdogg2 Posts: 27,572
    well my thought is using balanced most I thought send in phase and out of phase signals on the cable to reject noise. Am I wrong in that assessment?
  • Jeremias Larrea
    Hi Guys. will L800 work with McIntosh MC303?
  • Jeremias Larrea
    I have a Denon AVR A110 ...I was setting up the speakers I sent the test signal to the left and I heard the tone in both Right and Left. Is it normal because they have the SDA cable?
    audioluvr Posts: 6,013
    Yup.
    F1nut Posts: 52,164
    Ask McIntosh if the topology is balanced differential. If it is, you cannot use it with the L800.
