Built in cone dampening
I find better results with green painters tape. The bass is much tighter, and digs a little deeper.See my profile for list of gear.
should we wait for @Viking64 or shall I mention the difference between damping
and dampening at this point?
... besides...
heck, we all know that buffalo plaid duct tape is the best thing to use!
EDIT:
PS let's add another photo here from the ad (which, face it, won't be around forever) for posterity's sake, and to add even a little more context to this... umm... abomination.
I think I need some of this.
5am this morning woke up to one heck of a Crash!
Came from closet.
Went in there and one of the wire shelving racks had come off the wall. Totem Rainmakers sitting on the floor from an 8’ fall. Gouged up and looking terrible, but still in tact (have not tried to play them yet- might be internal damage).
Sad 😞 -
Oh man, that sucks, hopefully an easy fix- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Eh.
One of them was relatively unscathed, the other has damage that will not be fixable
It does seem though that there are no loose parts on the inside, I will see if I can test them later to make sure they are both working properly
First time hooking these up since that crash. They work. And nothing loose. The grilles were trashed, but the speaks have just a few scuffs and work great. Whew. I’ll be keeping them.
Awaiting new in case anyone was wondering.
What ya getting Joe- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Not really a change. But I’m hoping better on what I already have.
Trying the bookie version of the elacs. AS-61 plus the Elac stands.
The towers are great and very happy with them, save one thing. The tweeter is 48”AFF
As you remember that is considerably higher than ear level. And in my space I think the height of the bookie (at almost 10” lower) will serve the space better. I will up the crossover on the P6 to 50hz
Keeping the towers for now to make sure it’s what I want, but I have really come to love these speakers. So this is the best of both worlds for me.
Enjoying the Rainmakers which really sound good right now. That Seas metal tweeter is super detailed. -
Gotcha and yes the towers tweeters are super high, I'm sure the monitors will sound great- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thank You. Hoping so too.
One arrived today and other will be here tomorrow.
Shipments took two very different Paths from the same origin. FedEx = dopes.
