sound bar turns off
My Magnifi Soundbar is turning itself off every few minutes. Please advise
sn#AM811209246
Date code 3083143
  • wksnow
    wksnow Posts: 2
    The soundbar turns itself off after about 12 min almost consistently
  • Karla
    Karla Posts: 3
    My brand-new dsb 1 soundboard turns itself off, does not work well AT ALL. No manual. Options besides returning it for my $.
  • Karla
    Karla Posts: 3
  • Karla
    Karla Posts: 3
    Not soundboard, SOUNDBAR.
  • [Deleted User]
    [Deleted User] Posts: 7,598
    The first place to begin would be with Polk at: 1-800-377-7655 and select option 1.
  • joesephK
    joesephK Posts: 53
    The signal input into the bar must be too low... Check to see if there is a way to adjust the volume level for the optical output on your tv or device? Make sure TV speakers are turned off in audio settings menu in TV as well. If you must, turn up the source/tv and turn down the bar itself to prevent this.
