Can i hook up 2 of my polk audio sda 2 to my strdh-590?
So i have 2 polk audio sda 2 that i just got and i was wondering if i could hook it up to my sony strdh 590. Will it over heat it? Is gonna be too much power for that receiver? Also i had a polk audio sub that i want to hook up but the receiver already over heats when i turn up the bass and the volume on the sub 😅 or can i just adjust the speakers and the sub to where my receiver will not overheat and will be fine.
Answers
  • [Deleted User]
    [Deleted User] Posts: 7,658
    In all honesty I don't believe that would be a good idea. No offense to the Sony receiver, but it would be better to consider a high quality two channel integrated amp or a good quality preamp and power amp combination.
  • In all honesty I don't believe that would be a good idea. No offense to the Sony receiver, but it would be better to consider a high quality two channel integrated amp or a good quality preamp and power amp combination.
    What would you suggest?
    F1nut Posts: 51,772
    therussian wrote: »
    What's your budget?
  • F1nut wrote: »
    therussian wrote: »
    What's your budget?
    200- 300
  • [Deleted User]
    I would recommend a second hand NAD integrated amp or receiver, from a dependable source.
