Fur collar for my whizzers !
Polkaguy58
I'd seen this mod done before in pictures and now that I'm snowed in for a day or so, I decided to try it out.
I laid both of my Tannoy/Dayton full rangers side by side and then treated one whizzer with a twisted up piece of dacron fiberfill, gently stuffed behind the whizzer's cone.
It's supposed to dampen the movement somewhat and diffuse the back waves off of the whizzer from bouncing off the speaker cone.
I ran the tip of my finger lightly across the edge of the treated whizzer, listening to to see how much it differed from the untreated speaker.
There was an audible, less tinny sound, so I did up the other speaker and gave them a listen.
All I can say is WOW !
I used to have to set my Marantz's mid tone control back a bit to tame the HONK, but now have the amp on Pure Direct mode.........and it sounds great !
The nice thing is that it's totally reversible, with no permant mods to the speaker.
I need to give this a try. My whizzer has been a bit chilly of late.
ahh, the ol' '98 cent Lowther tweak' from Mark Wauters.
It can help a shouty driver (like a Lowther) -- better to go with a non-shouty driver in the first place, though, methinks.
It really makes sense having something to break up the rear waves off of the whizzer, while slightly dampening excess vibrations.
I thought you found a girlfriend...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Here's a new upgrade whizzer mute that I made from a foam port bung.
I used an electric knife to slice a couple 1/4" thick circles and then poked a pair of Fiskars through the center and cut out a donut hole.
Then I slipped them over the whizzers, like mounting a motorcycle tire, sliding one side under and working the rest around the rim.
They work great !
How's this mod holding up? I like your idea and want to try this on my phase-plug modded 6502's to cover up the voice coil leads and clean up the final looks.
Is there an aftermarket item similar to what you did?Don't take experimental gene therapies from known eugenicists. -
It's held up just fine.
All I did was use an electric knife to slice two pieces off of those cylinder foam bungs that come with some speakers to block the ports.
After that, I poked a pair of scissors through the middle and cut out the center, leaving a ring.
Stretch the ring over the whizzer cone and it seats itself.
It makes a lot of sense, as the foam keeps sound from emitting from the back of the cone and bouncing off the speaker, while damping any excess vibration from the whizzer. -
@ anybody. Do you have another name or a better description for that foam? I want to put SOMETHING* around my tweets to control diffraction
* no actual contact
https://us.v-cdn.net/5021930/uploads/editor/lj/u7sbh2yc8wl2.jpg
Thanks TonySamsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work -
* no actual contact
Thanks Tony
"No actual contact" won't work for the whizzer mod described in this thread. The contact is mission critical, as the fur, cotton, wool, or foam is damping resonances (or something like that) in the parasitic cone.
For diffraction, you can cut a thin piece of foam to fit around the tweeter dome (if it's a dome tweeter) -- this was all the rage in the late '70s. The foam folks use to make replacement 'socks' for DCM timewindows would work well. It is a stock product available from McMaster-Carr (or at least it was).
As I recall, Vance Dickason's Loudspeaker Design Cookbook describes making concentric circles of foam to improve (i.e., minimize) diffraction. That was popular in the old days for a while, too.
mhardy6647 wrote: »@ anybody. Do you have another name or a better description for that foam? I want to put SOMETHING* around my tweets to control diffraction
* no actual contact
Thanks Tony
*RTi/RTi A series
** if it works
Many thanks, Tony
RtiA line is notoriously bright. Be interesting to see what you come up with to tame them.
I mean, the brightness of the (in)famous Yamaha NS-10M studio monitors was famously often tamed with some tissue paper.
https://www.bobhodas.com/examining-the-yamaha-ns-10m.php
EDIT: Heh: https://www.madisoundspeakerstore.com/acoustic-damping/dampers-felt-defraction-ring-for-tweeters/
so, I am drawing a blank for the precise 'recipe' I am remebering so I will have to look at some actual, physical books. Pity me.
meanwhile, this might be of interest, @gp4jesus
https://www.audioasylum.com/cgi/vt.mpl?f=speakers&m=315155
Now where to buy?RtiA line is notoriously bright.Be interesting to see [hear] what you come up with to tame them.
* tri-amped
We’ll see Thanks
