Rubber feet for my Mini Dancer 2?
afterburnt
afterburnt Posts: 7,892
I have the rubber feet that cover the spikes on my 707's so it's easy to place them without wrecking the floor before settening them on the disc. Does anyone have an idea on what I can use on the Dancers weird spikes to accomplish the same thing?
  • Mikey081057
    Mikey081057 Posts: 7,127
    hockey pucks
    Garage | Polk Monitor 5B's
  • afterburnt
    hockey pucks
    Good idea, I need to be able to place the and just tilt them to set em into the disc. I do need some kind of non maring feet that will stay on when I stand them up.
  • Mikey081057
    If you drill them to fit snug...
    F1nut Posts: 49,806
    I wish I knew where to get those rubber slip on boots that Polk uses, pretty neat stuff. However, there are floor discs for speaker spikes available all over the Net.
  • afterburnt
    Jesse, the problem is getting the spikes to land in the disc.
  • afterburnt
    I think if I get some corks to jam on the spikes that might work.
  • PSOVLSK
    PSOVLSK Posts: 5,064
    edited May 2020
    https://herbiesaudiolab.com/collections/loudspeaker-rack-decoupling-and-isolation
    These are out of my budget, but maybe not yours. I have some cheap alternatives for my MD2’S, but I can’t remember where I got them.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,082
    Use a good file to flatten them!!
    Harry / Marietta GA
    msg Posts: 9,466
    Bruce, I think in this case, you could place the speakers first without the spikes installed. Then once in position, lean them back and install the spikes one at a time on top of their discs.
    You could initially protect the floor by placing the unspimed speakers on a folded towel or something.
    I wonder if you could use discs and floor sliders together initially to help with placement.
  • steveinaz
    steveinaz Posts: 19,522
    edited May 2020
    Jesse
    At the auto parts store (Autozone) I found a package of various sized rubber "caps" as I needed a larger one for a bypass on my airbox intake manifold connection. There were many sizes in the package.
  • steveinaz
    Here's a pic:
  • Mikey081057
  • gyosa
    gyosa Posts: 701
    Yeah .....
    Those Herbie’s are NOT cheap ....
    I considered them a while back until I added it up and it was @ $250 for a pair of speakers ....
    I made my own ....
    Bk
    Dayens Ampino , Yamaha wxc-50 , Polk SDA 1c’s ( my first love .. ) , Kimber Kable 4TC, Sony 42” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Yamaha wxc-50 , Kimber Kable 4vs , Salk Supercharged Song towers ( difficult choice between these and my family if I had to choose ... 😩 ) , Sony XBR-A8F 65” OLED - DEN , MAIN RIG
    PS Audio S300 - sitting in the closet for now …
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sharp 65” TV - PATIO
  • afterburnt
    To be clear I am going to use the Ushers' spikes set into the little disc. The 707's have rubber caps on their spikes so that once you place them you can tilt them a little, remover the little rubber cap, and set them in the disc. The Users have kind of weird spikes that are shaped like a trumpet bell so it is a little hard to get any kind of cap to stay on them.
    F1nut Posts: 49,806
    steveinaz wrote: »
    Jesse
    Steve, thanks for the suggestion. The ones Polk used are a combination of a thin metal spike with a heavy duty rubber boot which slips onto the spike. The spike alone is pretty much junk, but the slip on rubber boot is excellent. Let me see if I can find a pic.
    F1nut Posts: 49,806
    This is the best pic I found. It shows the boots on the spikes.
  • afterburnt
    Hey Jesse, should I be upgrading my spikes? If so what with what, they are still in the boxes?
    F1nut Posts: 49,806
    Bruce, I'm not familiar with the spikes that came with your speakers.
  • afterburnt
    @F1nut I am talking about the 707 spikes.
  • afterburnt
    I found a solution. I cut some synthetic wine corks in half and jammed the on the spikes. It worked like a charm. Drinking wine with chicks paid off in a small way. It wasn't worth it though, I hate wine more than I hate chicks.
    msg Posts: 9,466
    ^^ Signature material
