Why is the sound distorted?
The system is hooked up to a Panasonic plasma tv using the optical cable as there was no free hdmi port. It worked very well for the first couple of months. Now there is significant distortion that appears to be coming from the sound bar. Not noticable from the subwoofer. For a while the soundbar would settle down after playing for about 5 minutes but now that seems to take longer and longer. I have triied it through both the tv and bluetooth with similar result. The soundbar has been on for about 2 hrs. and I am playing a concert from my phone cast to the tv and it currently sound fine. Is it just going get worse or is there some reset that could be done to the soundbar?
Answers
    Clipdat Posts: 13,100
    Call 1-800-377-7655 select option 1.
  • gmcman
    gmcman Posts: 1,860
    edited May 2020
    Check the connection of the toslink at the TV. Those connections have been known to break. Also, try another toslink cable.
    F1nut Posts: 52,008
    Maybe lower models have less, but there's 6 HDMI ports on my Panny plasma.....six!
  • CottageChz
    CottageChz Posts: 419
    edited May 2020
    Dang, six is a lot! I heard those Panny plasmas were really nice. I got the last high end plasma model that Sammy made and it only has four. Occasionally I could actually use those other two!
    F1nut Posts: 52,008
    I use only 2. What da hell are yutes pluggin' in it?
  • CottageChz
    Haha. Roku, PC, Blu-Ray and Xbox. You could say some of that is redundant. If I had cable I’d need another, and every once in a while someone wants to hook up a laptop without unplugging something else.
