Best center speaker for vintage Polks.
I picked up a pair of Polk Audio model 4's with the square tweeters (Dynamic I guess) for $30:00 which pair will with my Polk Audio model 7's. I was hoping someone could recommend a good match for a center speaker. Thanks.
I would highly recommend a CS400/400i. They have the same size/vintage drivers as your Monitor 7s - always a plus to have your front three timbre matched. I’m currently using the 400 with both my SDA-1C fronts and Monitor 7 (or 10) fronts, an awesome pairing.
Where are you located? Anywhere near the Minneapolis/St. Paul area? I have a CS400 in excellent condition that’s available.
I'm afraid I'm in SLC but I'll keep an eye out for one thanks.
I just checked on Ebay for a Polk audio CS400, I was able to find the grill. Hahahaha
Good luck, they do pop up from time to time. It is a great center. Very capable.
Welcome to Club Polk!
Where’s SLC? -
teekay0007 wrote: »Good luck, they do pop up from time to time. It is a great center. Very capable.
Where’s SLC?
Salt Lake City Utah -
If you’re in the SLC hood, here are a couple of local listings that might fit the bill for you:
This dude is right off the freeway south of Orem, I’ve bought from him before.
CSi3 for $80
https://classifieds.ksl.com/listing/59422013
CS245 for $50
https://classifieds.ksl.com/listing/59439603
And this dude is selling three Monitor 4’s and a pair of RT8TL's in Provo:
https://www.facebook.com/marketplace/item/214891613275141/
He’s been all over the place with the price. Probably could get the lot of them for $120.
I’m in Farmington, happy to help a fellow polkaholic!Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩 -
My monitor 7's have one peerless and one silver tweeter (It's the way they were when I bought them) and I'd like to replace the silver with a peerless so I'll keep an eye on them thanks for the good info.
Make sure the two models are the same before you go swappin' tweeters willy-nilly. I am NOT the expert -- someone else here will know for sure -- but I reckon that the XO was different for the "Silver Coil" tweeter relative to the Peerless.
Now, if someone just dropped a Silver Coil dome tweeter in to replace a borked Peerless... well... that's a different matter.
I believe he is referring to SL1000 tweeter. They would fit the peerless cut out. I believe the xo was still a bit different than the peerless.
So I plugged in a Polk audio RM6000BD center I had lying around. It's not a match made in polk heaven but it will do until I find the CS400/400i center you all recommend. Thanks for all the good help I'll keep you posted.
I'd get that RTA8TL if I were you, that way the 7s can be used for what they're made for (music). And then you could add the 4s in for 7.1 or more.
I am using them for music. The model 4's are sitting behind my model 7's and on top of my Kef Q70's (which I have hooked up to a separate system for watching movies) and they (along with my model 7's) are used only for music. and Youtube. Thanks for the advice though.
Sorry, I assumed that since you were looking for a timber match for your 7s, that you were building a vintage surround setup.
Ya I can see that and I hadn't really considered it until you said something and your kind of right but the direction I'm trying to go is the best sound for music I can get on a budget. -
Would any CS center match timber are do I need the 400/400i's I'm asking because locally there's currently a cs1 and a cs10 available. Thanks
I was poking around in the closet and you'll never guess what I found; A pair of Polk audio model 4's I picked up at the DI thrift store for $10 a year or two back. One of them needs a tweeter lead repaired which I started on a long while back and never finished which I guess is why they were in the closet. But the one that is working is a perfect timber match to use for my center so I will use that until I'm able to get a hold of the ever allusive cs400/400i. Thanks for the advice.
Hi. I have a Polk audio CS245i center speaker that Iv'e had for years and I would like to know if it would be a good timber match for my current speaker set up are if I should continue to use the Polk audio 4 moniter speaker Iv'e been using and keep an eye out for a cs400/400i Thanks.
Front - Polk Audio 7 monitor
rear Polk Audio 4 monitor -
So I finally got around to hooking up the Polk audio CS245i center speaker I had lying around from a previous setup and I'll have to give it a week or two to see if it's a match made in Polk heaven but one thing is clear there's a noticeable difference between a center speaker and a book shelf speaker when used in the center position. -
Using an LSiM 704 with modded RTA 12c’s as front L-R’s with Excellent results."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
The price of those things they aught to be able to wash your dishes.drumminman wrote: »Using an LSiM 704 with modded RTA 12c’s as front L-R’s with Excellent results.
A while back Polk released a list of centers to go with vintage Polk speakers.Stan
Main 2ch:
HT:
Other stuff:
Awesome thanks I'll check em out. It's to bad you can't delete these things.
Awesome thanks I'll check em out.A while back Polk released a list of centers to go with vintage Polk speakers.
I'm using a CS250s with my RTA-11TL's with RD0-198 tweeters. They blend fairly well. My S8 blend even better since they have nearly the same tweeters.Stan
Main 2ch:
HT:
Other stuff:
For movies it's better for music it's a toss up. There not bad just different from the Polk 4 I was using for center.
