All I have to listen to are
afterburnt
afterburnt Posts: 7,892
Some Monitor 40 series II but at least they're are hooked up to a Parasound A31 :'( . By Monday everything will be boxed up and I will have nothing to listen to but the wailing and gnashing of teeth that plays in my head.
    mhardy6647 Posts: 35,201
    edited April 2020
    old time amalgam tooth fillings would sometimes act as detectors and pick up strong local AM radio stations.
  • afterburnt
    Kex wrote: »
    It”s not the stations 📻 that are the issue (plenty of options for those on a phone these days)...
    What he needs is a Beats Pill, a HomePod, or something similar of the Bluetooth variety!
    @Kex What are these things that you speak of?
  • rpf65
    rpf65 Posts: 2,127
    F1nut Posts: 51,953
    afterburnt wrote: »
    I didn't think you were moving for a few more years.
  • afterburnt
    Jesse I will be retired June 1st so I am well into the process of moving.
    F1nut Posts: 51,953
    Ah ha
    Viking64 Posts: 7,615
    I'm almost certain that was the premise for an episode of "The Brady Bunch". :o
  • afterburnt
    Viking64 wrote: »
    No, that was braces on The Partridge Family of Ben Casey.
    audioluvr Posts: 5,982
    Gilligan had that problem on one episode long before the Bunch...
