Monitor 5... Suitable for Rock/Metal
JohnGalt
Hey Guys and Gals. I came across a pair of M5's locally for a hundred bucks. I want to get something for my teenage son for in his bedroom. I have never had the privelage of listening to a pair so I am wondering if these would be suitable for his taste in music and if it is a good deal?
(I'm not sure if we are allowed to post links to CL listings here so I will not until I know its OK.)
He listens to classics like Led Zeppelin, Black Sabbath, and new stuff like TOOL, Mudvayne,.... etc.. His room is good sized.
He doesn't listen at super high levels and he will be driving them with a Harman Kardon HK3890.
Whatcha think,.... should I jump on them?
Yes. That's a good start.
Then he can move up the Polk speaker ladder which is what a lot of us have done.Most people just listen to music and watch movies. I EXPERIENCE them.
I should have added that I can hook him up with a Dayton Audio Sub-1200 If needed.
There are several versions of the Monitor 5s. Do you have a photo? All versions roll off in the mid 40s, so a decent sub would fill in the low end nicely.
Home Theater/2 Channel:
dhsspeakerservice.com/ -
I believe they are just 5's... Here is a link... (Mods take it down if you need to. I know some forums dont like CraigsList postings.)
https://seattle.craigslist.org/see/ele/d/federal-way-polk-audio-monitor-5/7103746815.html
Look to be in decent shape. -
Mid 80s full size with the 8" Passive Radiator. Excellent Speakers. Looks like the bottom has some swelling. Might have been stored in a damp location at some point. If you do get them, you should also consider upgrading the tweeters at some point, and possibly refreshing the crossovers.I believe they are just 5's... Here is a link... (Mods take it down if you need to. I know some forums dont like CraigsList postings.)
OH yeah I am an XO tweeker. Figured new caps would be in short order. Not sure if thats water swelling or if they have been droped. I am waiting on reply from the owner.
They remind me of a pair of Infinity rs 425's I owned many moons ago. -
I was reading on here about the tweeter upgrades. These look to be the 2000 model. Is the 1000 a better tweeter? what tweet do most people move to? I also have a bunch of loose tweeters and am thinking the Philips AD 0163-T8's silk domes I have mite work well
You will want the RD0194 in those, as they are the replacements for the SL models.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Be sure to run them with a high current amp, they like the juice. The 5s alone will work great with the older rock and metal, but the newer stuff will require a sub to help keep up with the bottom end.
nooshinjohn wrote: »You will want the RD0194 in those, as they are the replacements for the SL models.
This ^^^ drop-in replacement, or you can modify them for the RD-0198.
Stock:
https://us.v-cdn.net/5021930/uploads/attachments/4/6/7/2/8/18766.pdf
SL3000/RD-0198 modification:
https://us.v-cdn.net/5021930/uploads/attachments/4/6/7/2/8/18767.pdf
