Where do I get test tones?
Codey
Codey Posts: 188
I can't seem to find anywhere to download test tones from. Can anyone help?
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360
Post edited by Codey on
  • tryrrthg
    tryrrthg Posts: 1,896
    edited January 2005
  • Codey
    Codey Posts: 188
    edited January 2005
    Thank you very much. :)
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • opus
    opus Posts: 1,252
    edited January 2005
    Codey,
    If you have dial up like I do, downloading is a real bit*h. I would be happy to send you a copy.
    .....kevin
    The Flea rig
    Hitachi 50VG825 LCD
    Rotel RSP 1066 (pre) :)-flea market
    B&K St-202 (mains)-flea market
    Carver M 200t (x2) (center and surrounds)-flea market
    Blu-Ray..PS3 (dvd player)
    Polk RTA-11t-flea market
    LsiC, Fxi30's
    Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
    Behringer Feedback Destroyer
    -flea market
    AudioAlchemy DDE v1.0 DAC-flea market
    Cambridge Audio Azur 640 CDP-flea market
    Signal Cable and Kimber Kable
  • Codey
    Codey Posts: 188
    edited January 2005
    I appreciate the offer Kevin, but I've already got them burned to disk and ran a test. Thanks anyways.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • Codey
    Codey Posts: 188
    edited January 2005
    Either of you guys wouldn't happen to have the correction factors for using the Radio Shack SPL meter would you?
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • Mjr7531
    Mjr7531 Posts: 856
    edited January 2005
    Have you tried WinISD? They have a Sine Wave generator built in, you can make sweeps from 10 to what you wish, fast slow, with white noise.
    http://www.linearteam.dk/default.aspx?download=winisd
    Matt
  • gatemplin
    gatemplin Posts: 1,595
    edited January 2005
    You can get the correction factors here, look towards the bottom. There are also lots of other good stuff there.
    http://members.tripod.com/~terryctheater/shivaphotoalbum/page12.html
    Graham
  • McLoki
    McLoki Posts: 5,231
    edited January 2005
    Here is an excel spreadsheet that has the correction factors built into it (as well a few helpfull graphs)
    Here is the Excel file
    Michael
  • Codey
    Codey Posts: 188
    edited January 2005
    Thanks for the quick help guys. Here's the graph I just made but I don't really know what it's telling me. Is it decent, or do I have a lot of work ahead of me?
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
    VR3 Posts: 29,697
    edited January 2005
    I have test tones with correction factors, want em - got aim? msn messenger? email? etc
  • Codey
    Codey Posts: 188
    edited January 2005
    I've got 'em now thanks.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • McLoki
    McLoki Posts: 5,231
    edited January 2005
    It looks like you have it set a little hot, but all in all doesn't look bad. With a decent PEQ it would at least be very correctable. (no major dips to contend with) You could try some different placement options, but since it is so correctable, I would check into a BFD or other PEQ fix things.
    Then again, if you are happy with how it sounds, stop taking measurments and just sit back and enjoy it. :)
    Michael
    Edit - fogot, check into changing the phase as well. (if you do not have a setting for this, just hook the speaker wires up backwards and run the test again)
    VR3 Posts: 29,697
    edited January 2005
    Anyone that wants the Gomer test tones and the correction factors made for them, let me know.
    I have them all labeled and everything...
  • gatemplin
    edited January 2005
    Codey,
    Where is the crossover and are there any other speakers playing during this test?
    Graham
  • Codey
    Codey Posts: 188
    edited January 2005
    Yeah I know it's a little hot, I was showing off the LOTR ring drop scene for my brother and forgot to turn it back down. After I play with the phase and am finished messing around I'll recalibrate it.
    I had the crossover set to 150hz , but I stopped running tones a 125hz. There weren't any other speaker on for the test.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
    VR3 Posts: 29,697
    edited January 2005
    Ouch, thats why -
    Turn on the speakers and reset the crossover again and try it again, should have ALOT better results...
  • gatemplin
    edited January 2005
    That is good. This gives us an idea of the room faults. We both have similar subs and rooms. I highly recommend picking up a BFD to tame that curve.
    Here is a sample, my curve look nothing like this anymore (I change it like once a month) but it gives you an idea. I was going for a house curve. I had to turn the gain up but 250w is plenty for a big Tempest.
    Graham
  • Codey
    Codey Posts: 188
    edited January 2005
    I'll turn on the speakers and run it again, I just wanted to see how bad the room was and whether I should move to a house with better acoustics. ;)
    I was just looking at the BFDs, do they come in version that's not butt ugly? Do you think it would be a worth while investment in my case?
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • McLoki
    McLoki Posts: 5,231
    edited January 2005
    Nope - butt ugly but cheap and effective. thats what you get.
    And yes - it would do wonders for you.
    Michael
  • Codey
    Codey Posts: 188
    edited January 2005
    Maybe I could just put it in a paper bag or something.
    How do they hook up, is it just the sub out that comes in and goes out to the sub?
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • McLoki
    McLoki Posts: 5,231
    edited January 2005
    yep. It is a stereo piece of equipment and has xlr or 1/4" jacks.
    I got 2 1/4" to rca adapters at Guitar center (about $5.00 I think).
    I went sub out (on the avr) to left in (on the bfd) then got another cable and went from left out (on the bfd) to sub in (at the sub).
    Thats all you need. 2 1/4" to rca adapters and one additional sub cable (assuming you have one that works now.)
    Michael
