Handwritten Capacitor Values?
Does anyone know why the rating on these Sonic Caps appears handwritten.
Has a cap of a different value been modified, or has the stamped rating simply been altered?
photo borrowed from another current thread:
https://us.v-cdn.net/5021930/uploads/editor/s0/fn2sqbg9s2qp.jpeg
  • CH46E
    CH46E Posts: 3,595
    I'm not sure why, but I had the same thing happen on the Sonicaps I used for my JBL L80t rebuild.
    I wonder if they were made for one value but tested at a different value. Or they may have been a customs value that they made a limited batch of????
    F1nut Posts: 52,008
    Once the cap is made you can't alter the value, so definitely not that.
    Almost looks like a printer problem as part of the u is also touched up. You can always measure the cap to check the value and feel free the call Sonic Craft to ask why. Real nice friendly folks.
    F1nut Posts: 52,008
    These excellent caps always come with the value handwritten and cost significantly more than Sonicap.
  • westmassguy
    westmassguy Posts: 6,850
    edited March 2020
    According to their product description: "Tolerance is better than 5%". After a production run, all the capacitors are measured. If their measured value falls outside the + or - 5% tolerance, they're put aside, and sold as custom values. 33uf is a common value available from many different manufacturers. 34uf isn't, but I'm pretty sure Jeff knows Polk's vintage Monitors use that value a lot, so he probably bins high value capacitors from a 33uf production run that are within 5% of 34uf, and hand labels them.
    Every 34uf Capacitor I've ordered from Sonic Craft was handwritten.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Astrl55
    Astrl55 Posts: 68
    Thank you all for the explanation -- this forum is one of the highest and best uses of the internet.
