Opinion on MIT AV-2 Shotgun bi-wire is needed, please
polkatese
polkatese Posts: 6,767
edited January 2005 in Speakers
All,
Would you, could you? also, fair price on this? I tried to dig the diffrences between all MIT line, but got lost on the details, so, if anyone could give me the cliff-note version, appreciated...
Jesse? Mark? Bueler?
Thanks a bunch...
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2005
    AVt (Good)
    Shotgun (Better) * I think this line is the best bang for the buck from MIT
    Magnum (Best)
    Oracle (You're spending too much money)
    I would suggest the Shotgun S3 as a great starting place and most likely ending point for MIT.
    I would drop an email to Joe Abrams, Audiogon, and check him out. He has the best prices for brand new MIT around, to my knowledge. 50% off MSRP.
    If you really get serious, drop me a line, as I would be willing to let you borrow a Shotgun S3 for a demo.
  • polkatese
    edited January 2005
    thanks for the offer, I might take you up on it, Mark. So, is this:
    http://cls.audiogon.com/cgi-bin/cls.pl?cablspkr&1111550059
    from their AVt line or Shotgun line?
    Is Joe Abrams the Cable Nerd guy? (tcnerd.com)
    Compared to Signal's Shotgun, your take (since I know you have both)?
    I am saving the Oracle for my Levinson, when I get to it ;) (which ain't goin' to happen in this lifetime)
    Thanks again, Mark...
    F1nut Posts: 51,763
    edited January 2005
    No, this is the guy you want. http://cls.audiogon.com/cgi-bin/cls.pl?cablintr&1111860119
    I wouldn't bother with the AVt line, start with the Shotgun series, it'll most likely be all the cable you'll ever need.
  • polkatese
    edited January 2005
    Thanks, Jesse - email went out to him, did you get yours from him also?
  • dorokusai
    edited January 2005
    Jesse found Joe in his travels and hooked me up with him as well. He uses the Shotgun S1 and I use the S3. The S1 is the higher end of that line....S1, S2 and S3.
    F1nut Posts: 51,763
    edited January 2005
    :D
  • polkatese
    edited January 2005
    well, Joe came back with the quote, thanks guys.
    F1nut Posts: 51,763
    edited January 2005
    SO? Did you buy some?
  • polkatese
    edited January 2005
    Not yet, I need to call him tomorrow to discuss options. He has no inventory on S3 biwire.
    F1nut Posts: 51,763
    edited January 2005
    Personally, I wouldn't buy bi-wires again, but that's just me. I'm actually running MIT bi-wires with MIT jumpers and like the sound much better, therefore wouldn't spend the extra cash for bi-wires again. What speakers are you hooking up?
  • polkatese
    edited January 2005
    Jesse,
    that's one of the options that I am considering. It will be used for LSi15 and the Krell 400xi. An overkill, perhaps?
    F1nut Posts: 51,763
    edited January 2005
    Overkill in the sense of bi-wiring? No, I don't think so. Overkill in the sense of using MIT Shotgun cables, Hell No!
    I'm just relating my findings with my gear, your experience will most likely be very different, as different as our gear. You can always get the bi-wires and if you're not happy or just want to play around, get some MIT jumpers later. I think they ran me about $100.00.
    BTW, tell Joe I said Hi!
  • polkatese
    edited January 2005
    hence the quandry: To Bi or Not To Bi
    I suppose the only cure is experimentation. We'll see, I guess. I'll let Joe knows, it could be my ticket for In-Home demo for both versions, who knows?? thanks..
  • dorokusai
    edited January 2005
    I have no plans to bi-wire anything in this house, at any time.
    They look cool, but I don't subscribe to that benefit.
  • mantis
    mantis Posts: 17,377
    edited January 2005
    polkatese,
    this may be the time to try a biwire cable , then see if you can get the next level up single run cable with jumpers and see what sounds better. I always wanted to try this and haven't got around to doing it.
    I never had my Lsi15's single wired and would like to give that a try. My goal is to demo my Kimber 8tc 8tc shotgun bi wires against a pair of Kimber Monocole X single run with a pair of monocle jumpers.
    Good luck man,
    Dan
    Dan
  • danger boy
    danger boy Posts: 15,722
    edited January 2005
    well if you had never tried Krispy Kreme donuts. how would you now if you liked em or not? Or beer or Scotch or whatever your taste may be.
    Same with bi wiring. for me. i hear a slight improvement over single wires. Enough so.. that it's worth it. It's a inexpensive enough fix.. why not?
    PolkFest 2012, who's going>?
  • dorokusai
    edited January 2005
    I have tried it.
  • polkatese
    edited January 2005
    ok, took the plunge, Joe said: Jesse and Mark from Maryland? I supposed you guys are famous! ;)
    Mark, thanks again for the offer, I seriously was considering it, but don't want to cause undue burden on you.
    I went with the bi-wire, so, we'll see. I will report back.
  • dorokusai
    edited January 2005
    No kidding? LOL....more like infamous.
    It's an excellent cable, bi-wire or not, you should be very happy.
    F1nut Posts: 51,763
    edited January 2005
    Definitely infamous. :D
  • polkatese
    edited January 2005
    :D:D:D
    thanks, I am looking forward to it. Btw, Joe seems like a very nice gentleman (drinking bud kind)...
