Phase Plug design for MW65xx
xschop
Going to experiment soon on a set of 6502's.
The big question for one design is if a small neodymium magnet would work to attach the billet phase plug/cone to the inner pole piece?
I would be concerned about the magnetic field generated by the additional magnet causing unwanted interference with the original permanent magnet and voice coil. It might be better to use a moderately sticky adhesive that would hold it in place while you listen to the results.
What are you trying to accomplish (i.e., what are you trying to fix)?
Not meant to be as snarky a question as it sounds.
Not to denigrate @KennethSwauger's observation/comment at all, but in my one and only (to date) experiment/experience with installing a phase plug where none had previously been found was very successful. In my case, I used a magnet-equipped phase plug from Dave Dlugos ("Planet10 Hifi"). This was to improve the HF peformance (extension and quality) on a fairly pedestrian twincone "fullrange" driver, the R/S 40-1354. Subjectively, the result was beneficial, but I am less sure that the Polk midwoofers will benefit (as much?), given that the range of frequencies they're asked to reproduce are limited by the crossover. Don't have that luxury with the 40-1354.
To Ken, that's what I thought would be issue of mag field interference.
To Mhardy, It will be cool looking and may have an actual sonic benefit. I sold/ traded most my billet 5jr's. So I need to spend some time experimenting again. You of all should understand.Don't take experimental gene therapies from known eugenicists. -
I have to admit I don't know what you are talking about. Is it this that you want to do?:
George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
I have to polish up on my surgical scalpel technique on these dusty coil covers lol.Don't take experimental gene therapies from known eugenicists.
A little free* and unsolicited advice: practice on some cannon fodder drivers -- especially if you've never done it before. It's not hard but it requires a certain amoun of confidence (not one of my better things, at least when it comes to fine motor skills).
The pair of 1354s I performed dustcapectomies on were my spare spare pair.
EDIT: Oh, come to think of it -- if you have any friends or family members who need some minor, elective surgery, and "Bronze" level health insurance... well... it could be a win-win vis-a-vis your gettin' a little scalpel practice in.
FWIW, I actually didn't use a scalpel. I believe I used one of the thinner-handled X-ACTO knives with a brand new pointy blade, like this:
_____________
* and worth every penny.
Which shape would you choose for the MW phase plug and what's the sonic difference if any?
Quick perusal of this thread from DIYaudio (only the first page -- there are 10 pages) suggests it's worth a look.
https://www.diyaudio.com/forums/multi-way/192215-phase-plug.html
Bear in mind that phase plugs for compression drivers (although, presumably, intended to improve the focus and dispersion of the output of the driver) are implemented rather differently than phase plugs for direct-radiator cone drivers.
The whole thing about audio is that the range of frequencies (wavelengths) we have to deal with is quite broad -- a priori I would think some sort of smooth curve is 'better', but that's an opinion with very little to back it up.
I can remember seeing nice graphics that 'explain' how the phase plug helps to improve higher-frequency propagation &/or dispersion from a (cone) driver, but danged if I can find any of 'em this morning.
Take a look, also, at Dave Dlugos' products. Dave was sidelined due to some profound health issues a few years back, but he and his cottage business ("Planet10") were very influential in certain circles back in the glory days of 'full extended range' drivers and their care and feeding
https://www.diyaudio.com/forums/planet-10-hifi/39053-planet_10-hifi.html
Dave has always had a sense of humor about hifi!
My 40-1354 phase plugs are his, BTW & FWIW (& in case I didn't say that already!).
Of course, there're also some of the vintage Lowther designs -- some of which always make me think of Mister Magoo.
so... here's a pretty concise, and I believe accurate (if nontechnical), explanation of the phase plug.
source: https://db.audioasylum.com/mhtml/m.html?forum=hug&n=81485&highlight=phase+plug&search_url=/default.mpl?searchtext=phase+plug&b=AND&topic=&topics_only=N&author=&date1=&date2=&slowmessage=&ip=&sort=score&sortOrder=DESC&sortRank=Forum&forum=hugMost phase plugs look like bullets. They are placed with the (nominally) flat side facing the driver diaphram, with the intention of forcing the frequencies coming from the center of the diaphram to follow an equal path length to those coming from the more outer periphery of the diaphram, thus keeping them in phase with each other.
This EV description (from their T-35 family of tweeters) might also be of interest -- although, again, this is for a compression driver (and a rather harsh & aggressive tweeter, at least IMO).
https://www.electrovoice.com/binary/T350 EDS.pdf
oh, and some typically Steve Deckert-esque prose about his phase plugs.
https://www.decware.com/paper46.htm
(many of his tweaks, in fairness, get very good press)
I read through much of that. Feels like I was given homework hehe.
Now I can't find my old posts where I thought I mic'd the O.D. of a pole piece I had apart at one time.Don't take experimental gene therapies from known eugenicists. -
How far past the plane of the removed dust cap base will the bullet-shaped plug need to be?Don't take experimental gene therapies from known eugenicists.
Thanks to DowninMexico for the dimensions in his magnet resetting thread. I'll be making these 0.990" dia.
I'm starting with 5" lengths because the part-off has to be near the chuck jaws....
So quick I could only get finish pass pic....
Programming a couple thousandths off tip to clean up point....
I do (still) teach a grad-level course in my spare time, you know?
All jesting aside, I appreciate your candor and insight. Your link to the D200? plugs was a good starting point for these. Thank you.Don't take experimental gene therapies from known eugenicists. -
De nada... and your plugs look great!
I used precision shim washers...
I don't have a 4-place scale, but a couple grams worth of weight was removed....
To reiterate, I used .0875" O.D. phosphate coated steel shim washers. The magnetic force just from the pole piece holds them nice and tight....
Listening session tomorrow. About to do surgery to other cone.... Thanks mhardy for the scalpel tips lol....
A very interesting discovery, from what I can tell by ear, the plugs definitively clear up voices and instruments somewhere around 800-1200 Hz, especially when accompanied by bass notes.Don't take experimental gene therapies from known eugenicists.
Very intriguing! How much clearance would you say there is, between the ID of the voice coil and OD of the plug?George / NJ
iFi nano iDSD DAC
iPurifier3
The factory pole piece is 0.995". Phase plugs are 0.990" diameter. However the factory voice coil is a touch larger than pole piece itself obviously, and more than 0.003" difference either side.
I intentionally made these plugs 0.25" longer in case I didn't hear much difference and would shorten them down, but that's not the case.
I can make another shorter set and see if that changes anything in the lower octave, but mhardy's links and discussion doesn't seem to warrant that.Don't take experimental gene therapies from known eugenicists. -
Also, I do not detect any off-axis difference with plugs in or out, however I do have them in a 12x12 carpeted office, if that matters.
I Indeed detect the removal of tinnyness of Sade's voice in the specific track Stronger than Pride.... I'm enthused.Don't take experimental gene therapies from known eugenicists. -
Add Donald Fagan to the list.Don't take experimental gene therapies from known eugenicists.
Nice work. When do you start full blown production?
https://www.youtube.com/watch?v=9U1v01SGtGE
