receiver bass management - double bass vs crossover
my setup
rti10's paired with a smaller sub. listening to music
I was playing with my rti10's tonight and crossover points and realized that the bass felt a lot more fuller when i had double bass turned on. (fronts set to FULL) and the sub engaged as well.
i tested setting the fronts to diff crossover points upto as high as 80hz and it seemed like the bass was still fuller with the double bass turned on each time i tried a A-B compare.
Is that normal? Everything i have read is that a define crossover point is better.
Is my hearing failing me or is this alright?
    msg Posts: 10,463
    I tried that same thing back when I had RTi10s and running them off an AVR.
    I found the RTi10s to sound a bit lacking in the mids and bottom end, and had to crank them up to get them to sound fuller. What I didn't realize at the time was that it's just a hot speaker up top. They're made more for HT, and they do well there, but tough to find the sweet spot with them for music.
    In an attempt to fill in, I used whatever version of that "double-bass" function is for the AVR I was using at the time (entry-level Pioneer). Everything did seem to sound fuller, but I remember getting some feedback that it can cause problems with bass performance in the room, overall.
    Bottom line is there's no right or wrong here, just whatever works best for your space and system. I think the worst thing that could happen is that you could get some cancellation or muddied bass or something.
    Maybe some others can chime in here on this.
    You can also try searching on it. Here are a couple of articles to familiarize yourself a bit, and maybe lead you to more reading.
    https://www.audioholics.com/home-theater-connection/utilizing-extra-bass
    https://subwoofer101.com/setting-up-your-gear/large-vs-small-lfe-main-double-bass-etc/
  • mantis
    mantis Posts: 17,557
    The issue is your room and it's placement of your subwoofer and speakers. If your getting fuller bass with both reproducing the exact bass notes until the 10's fall off and the sub picks up then you need to place your sub better or add another one.
    Usually in most cases the left and right stereo speaker setup the position to your seat to the distance between the speakers and the way the room interacts with the bass notes is usually a mess. Crossing them over at 60-100hz somewhere in there will provide better dynamics, cleaner mid and high range clarity and allowing the sub when properly placed vs your seating location will provide much smoother cleaner more effective bass. Most of the time people are use to having to much bass and thing thats how it's supposed to sound. If you want a reference calibration you need to pay attention to your seating and sub relationship. Most of the time this is difficult to do as many of us have limited placement options. I suggest learning about the Subwoofer crawl and follow those guide lines. You will probably think your bass is slightly weak after a proper calibration but over time you will learn you can hear everything much cleaner and clearer.
    Level matching frequency response to your listening position is key my friend.
    Dan
  • thejck
    thejck Posts: 849
    thanks for the input.
    thinking about this. for music i think mid-bass is more important. the sub i am playing with is not very big and so its severely lacking in the low range but this is a secondary setup for a bedroom.
    I am wondering if double-bass setting is great for music because it compliments the mid-bass very well and most music only goes down that far anyway.
    I am not under any illusions that this sub is going to perform well for low bass HT scenes. but i have a diff room in the house for that experience.
    Nothing wrong with using the double bass option, if it sounds better to your ears, roll with it.
    mhardy6647 Posts: 35,219
    double bass... ?!? ;)
    Viking64 Posts: 7,622
    Double double bass.
    F1nut Posts: 51,981
    Viking64 wrote: »
    Double double bass.
    Damn, is that just for show or is that someone's drum kit?
    pitdogg2 Posts: 27,286
    edited March 2020
    they could do that Jesse. two pedals could work 4 bass drums. Just like now folk use one kick drum with two pedals.
    that might just be for show.
    If you want to see a serious kit check out Terry Bozzio's
    I know a lot of drummers tour with a quad set-up. I can't say for sure what the sonic benefits would be, unless you would want to isolate each kick head for some reason. That would make more sense in a studio, I would opine (italics/end italics). Although I would hate to have to mike it. :p
    A friend of mine posted video of his studio kit, which only had ONE bass drum. At the beginning of this clip, you can see how many beats are possible with a double pedal. It's quite astounding, actually.
    https://www.youtube.com/watch?v=M-Hx-Jd3sEM
    F1nut Posts: 51,981
    He certainly wouldn't have a problem hitting something...lol
    F1nut Posts: 51,981
    Viking64 wrote: »
    That is astounding.
    Freakin' awesome....
  • mrloren
    mrloren Posts: 2,474
    if you're using Audyssey check the phase on your sub.
    Set the C/O to 80HZ put on some bass heavy music listen for a minute. Flip the switch and listen to the same track again. Which ever has more bass leave it there.
  • thejck
    thejck Posts: 849
    my sub doesnt have a phase switch. is the other option to adjust the distance in the AVR to account for phase differences?
    F1nut Posts: 51,981
    tonyb wrote: »
    ^ This ^
