Monitor 10b xover rebuild.
sansuibutch
sansuibutch Posts: 198
edited March 2020 in DIY, Mods & Tweaks
Im rebuilding the the crossover on one of these speakers. I purchades one monitor 10b crossover so this is not a set of speakers. Its going to be used in a center channel " a design westmassguy created and awsome he shared with us all" . The parts of the crossover for the tweeter are going to be the same specs just new caps and resistors. I notice the tweeter circuit has a inductor, couple caps and a couple resistors. The schematic i see calls for a 2 ohm resistor and a 2.7 ohm resistor. My xover from the factor has two 4 omh five watt resistors in parallel to get the 2 ohm with 10watt rating. But the other resistor is a 2.5 ohm 5 watt resistor when it looks like it should be a 2.7 ohm. Was there any variations of the monitor 10b xover to make sense of this or do you guys think they were just out of 2.7ohm resistors?
Answers
