Just shipped an amp out for repair
BlueFox
in Electronics
Last Friday I went to listen to some tunes, and the right amp wouldn’t turn on. Great. It is only five years old, but I guess these things happen. However, I had to buy a box from Pass, and it arrived yesterday. Let me tell you, trying to get a 150 pound amp ready for shipment is work. Anyway, it just got picked up, so hopefully I will soon be back in business.
Until then I am listening to the cable music channels (Rock, Metal, Classic) and it sounds pretty good with sound bar.
Bummer Bud ☹️
I hope all ends well with shipping and repair. -
Me too.
Three 20 amp circuits. -
150 pounds?!
Hope you had an engine hoist. -
That's a big bummer for sure.
Sad you had to pay for the box considering the original cost of those beauties.
I hope it's still under warranty.Most people just listen to music and watch movies. I EXPERIENCE them.
You said that while drinking a chilled glass of Thunderbird, didn’t you? -
Maybe "Mad Dog 20/20" would be better.
I was kind of irked I had to buy the box, but not having empty boxes sitting around made it worth the cost. I’m not sure of the warranty. I guess I will find out. Now that I am retired I am getting nickel-dimed to death.
how much did they charge for the box? I've heard horror tales of $200 boxes :'(Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Not that bad, but still expensive. $100.Lumin X1 file player, Westminster Labs interconnect cable
What kind of troubleshooting techniques did Pass have you try before it was determined that the amp would have to be shipped in for service? -
Sorry for the amp troubles Bud.
I recently had a scare with my BAT VK-255SE. I sat down to listen to Floyd's Obscured By Clouds CD about a month ago, and found the left channel to sound distorted. I looked into the top of the amp and found both of the LED's on the left channel to be dim and/or out. I shut the system down and the next day sent an e-mail to Victor Khomenko at Balanced Audio Technology asking what may be wrong with the amp (The amp is only about 2 years old for reference). He said to replace the fuses in the left channel, which I did. That solved the problem! Not sure why the fuses blew (which unfortunately were the now unavailable Hi-Fi Tuning Gold fuses) but they did. Victor said it may be a "transient" voltage through the amp that took out the fuses in the left channel. Anyway, after replacing the left chanel fuses with the stock replacement fuses, the VK-255SE works perfectly.
I hope the repair of your Pass amp is as easily accomplished Bud. And I hope your warrenty covers your repair costs. Please let us know how things go.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
I can relate to the hassle of moving a 150lb amp. Mine are 3lbs short of that mark but I cannot imagine boxing one up for shipping. I'm thinking that has to be at least a 2 person job?
Good luck to you in having it fixed and arriving back home without incident. -
what's so bad is a lot of the new amps don't have handles. :'(Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Pass didn’t suggest anything as I only contacted them for return instructions. It was dead. I swapped AC circuits. No help. If a fuse is blown it is inside the amp. As Monty Python says, ‘This amp is dead. It has ceased to exist.’
motorstereo wrote: »I can relate to the hassle of moving a 150lb amp. Mine are 3lbs short of that mark but I cannot imagine boxing one up for shipping. I'm thinking that has to be at least a 2 person job?
I did it by myself. I placed the box on its side, and walked the amp into it. Then I walked that box into the shipping box. I was beat when done. If I didn’t have a hand cart to get the box from the living room to the garage I would have been in trouble.
The X600.5 does not use fuse protection. It has a magnetic circuit breaker. -
How far away are you from Pass Labs, Bud? If you are within 100 miles or so, I would have taken it there personally.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
He's roughly 150 miles away from them.
I did consider taking it myself, and decided not to.Lumin X1 file player, Westminster Labs interconnect cable
Throwing the dice on shipping. You're a bold man.
I would have drove. -
Sorry about your loss, @BlueFox ! I'm sure everything will work out for you! Do you have a spare amp to do the duty while the PASS is being fixed?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Cambridge Audio IIRC.
I have been listening to three music channels on the cable TV. I have a sound bar, and it sounds pretty good.Lumin X1 file player, Westminster Labs interconnect cable
If you need a new home for your gear, let me know.
Pass Labs could have provided wheels to move that 150 pound amp similar to what GE did for large transformers in Pittsfield MA in the 60's and 70's. I believe the largest transformers were assembled on the train flatbeds in the factory. My first job was with the GE Medium Transformer Division.
"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
Pass has the amp. Hopefully they will fix it, burn it in, and ship it back next week. Tonight is Tuesday beer and music night, so I will be listening to the Metal channel on the cable. I have to admit that it is tolerable with the sound bar. Just turn the picture off, and listen.
I get my amp back tomorrow (Friday). Hopefully, early in the day so it can warm up before nighttime listening. I am not looking forward to getting a 150 lb amp into the living room, and then on a shelf.Lumin X1 file player, Westminster Labs interconnect cable
Did they say what was wrong with it?
The real issue is unboxing a 150 lb amp, getting it onto the bottom rack shelf, hooked up, and powered on. Depending on when it gets here will determine if it gets hooked up today. If I get it before 4 PM then I will install it. Otherwise tomorrow.Lumin X1 file player, Westminster Labs interconnect cable
