Just shipped an amp out for repair
BlueFox
BlueFox Posts: 15,250
Last Friday I went to listen to some tunes, and the right amp wouldn’t turn on. Great. It is only five years old, but I guess these things happen. However, I had to buy a box from Pass, and it arrived yesterday. Let me tell you, trying to get a 150 pound amp ready for shipment is work. Anyway, it just got picked up, so hopefully I will soon be back in business.
Until then I am listening to the cable music channels (Rock, Metal, Classic) and it sounds pretty good with sound bar.
    pitdogg2 Posts: 27,261
    Bummer Bud ☹️
    I hope all ends well with shipping and repair.
  • BlueFox
    Me too. :)
  • krazypolk
    krazypolk Posts: 745
    150 pounds?!
    Hope you had an engine hoist.
    Tony M Posts: 11,690
    That's a big bummer for sure. :#
    Sad you had to pay for the box considering the original cost of those beauties.
    I hope it's still under warranty.
  • rpf65
    rpf65 Posts: 2,127
    BlueFox wrote: »
    You said that while drinking a chilled glass of Thunderbird, didn’t you?
    Maybe "Mad Dog 20/20" would be better. ;)
  • BlueFox
    Tony M wrote: »
    I was kind of irked I had to buy the box, but not having empty boxes sitting around made it worth the cost. I’m not sure of the warranty. I guess I will find out. Now that I am retired I am getting nickel-dimed to death. :)
  • marvda1
    marvda1 Posts: 4,962
    edited March 2020
    how much did they charge for the box? I've heard horror tales of $200 boxes :'(
    Puritan PSM156
  • BlueFox
    Not that bad, but still expensive. $100.
    Clipdat Posts: 13,100
    BlueFox wrote: »
    What kind of troubleshooting techniques did Pass have you try before it was determined that the amp would have to be shipped in for service?
  • headrott
    headrott Posts: 5,496
    Sorry for the amp troubles Bud.
    I recently had a scare with my BAT VK-255SE. I sat down to listen to Floyd's Obscured By Clouds CD about a month ago, and found the left channel to sound distorted. I looked into the top of the amp and found both of the LED's on the left channel to be dim and/or out. I shut the system down and the next day sent an e-mail to Victor Khomenko at Balanced Audio Technology asking what may be wrong with the amp (The amp is only about 2 years old for reference). He said to replace the fuses in the left channel, which I did. That solved the problem! Not sure why the fuses blew (which unfortunately were the now unavailable Hi-Fi Tuning Gold fuses) but they did. Victor said it may be a "transient" voltage through the amp that took out the fuses in the left channel. Anyway, after replacing the left chanel fuses with the stock replacement fuses, the VK-255SE works perfectly.
    I hope the repair of your Pass amp is as easily accomplished Bud. And I hope your warrenty covers your repair costs. Please let us know how things go.
  • motorstereo
    motorstereo Posts: 2,359
    I can relate to the hassle of moving a 150lb amp. Mine are 3lbs short of that mark but I cannot imagine boxing one up for shipping. I'm thinking that has to be at least a 2 person job?
    Good luck to you in having it fixed and arriving back home without incident.
  • marvda1
    what's so bad is a lot of the new amps don't have handles. :'(
    Puritan PSM156
  • tophatjohnny
    tophatjohnny Posts: 4,189
    krazypolk wrote: »
    150 pounds?!
    With all the heavy metal going on😂😂
  • BlueFox
    Clipdat wrote: »
    BlueFox wrote: »
    Pass didn’t suggest anything as I only contacted them for return instructions. It was dead. I swapped AC circuits. No help. If a fuse is blown it is inside the amp. As Monty Python says, ‘This amp is dead. It has ceased to exist.’
  • BlueFox
    edited March 2020
    I did it by myself. I placed the box on its side, and walked the amp into it. Then I walked that box into the shipping box. I was beat when done. If I didn’t have a hand cart to get the box from the living room to the garage I would have been in trouble.
    BlueFox wrote: »
    The X600.5 does not use fuse protection. It has a magnetic circuit breaker.
    nooshinjohn Posts: 25,991
    How far away are you from Pass Labs, Bud? If you are within 100 miles or so, I would have taken it there personally.
    He's roughly 150 miles away from them.
  • BlueFox
    I did consider taking it myself, and decided not to.
    Throwing the dice on shipping. You're a bold man.
    I would have drove.
  • verb
    verb Posts: 10,176
    Sorry about your loss, @BlueFox ! I'm sure everything will work out for you! Do you have a spare amp to do the duty while the PASS is being fixed?
    Cambridge Audio IIRC.
  • BlueFox
    I have been listening to three music channels on the cable TV. I have a sound bar, and it sounds pretty good.
    BlueFox wrote: »
    If you need a new home for your gear, let me know. :p
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,815
    Pass Labs could have provided wheels to move that 150 pound amp similar to what GE did for large transformers in Pittsfield MA in the 60's and 70's. I believe the largest transformers were assembled on the train flatbeds in the factory. My first job was with the GE Medium Transformer Division.
    Harry / Marietta GA
  • BlueFox
    Pass has the amp. Hopefully they will fix it, burn it in, and ship it back next week. Tonight is Tuesday beer and music night, so I will be listening to the Metal channel on the cable. I have to admit that it is tolerable with the sound bar. Just turn the picture off, and listen. :)
  • BlueFox
    I get my amp back tomorrow (Friday). Hopefully, early in the day so it can warm up before nighttime listening. I am not looking forward to getting a 150 lb amp into the living room, and then on a shelf.
    Did they say what was wrong with it?
  • BlueFox
    The real issue is unboxing a 150 lb amp, getting it onto the bottom rack shelf, hooked up, and powered on. Depending on when it gets here will determine if it gets hooked up today. If I get it before 4 PM then I will install it. Otherwise tomorrow.
