Joule LA-100 has landed in Verb's house!
13
  • verb
    verb Posts: 10,176
    tonyb wrote: »
    85 db's is still low. Not good juju with something. I could blast that puppy well into 120 with the legacy's, Butler, AZ cables. Seemed like the top volume was unlimited. 🙂
    Yep. Hey Tony do you recall if there was a switch or jumper inside to change the gain from 8 to 12db?
    F1nut Posts: 52,063
    Speaker cables (Shotgun S1's) have adjustable network boxes as well, IIRC
    Nope.
  • verb
    verb Posts: 10,176
    maxward wrote: »
    With my similarly aged Joule fed by the North Star DAC, I get 75-80 dbA with the gain around 10 to 10:30 and both balance controls at noon. So it seems like something is not right. Glad to hear it’s sounding good, though.
    What amp were you running with it?
  • verb
    verb Posts: 10,176
    Nope.
    Thank you sir! Save me the trouble from looking! :smile:
    verb wrote: »
    tonyb wrote: »
    I don't think so, but never went looking for one. Nothing obvious anyway. Might be something in the manual about it
    F1nut Posts: 52,063
    The LA100 MkIII had jumpers to adjust the gain, but I'm not sure about the LA100.
  • verb
    verb Posts: 10,176
    edited February 2020
    So I just had to go back downstairs and plug the CJ in! I got 8 more dB! Now at 93 dbA! :smile:
  • maxward
    maxward Posts: 1,721
    No jumpers in my LA-100. It is feeding Odyssey Khartago monos. It is rare that I have the gain control past noon and the Maggie’s are not known for being efficient.
  • verb
    verb Posts: 10,176
    Again a noticeable improvement. @tonyb you mentioned that the Joule when paired with the Butler amp really was a nice pairing, so I did a little digging.
    Here are the specs of the Butler amp:
    The MC300:
    CJ MF2300A
    McCormack DNA125 (did not hook up)
    Seems like input impedance is the discriminating factor here? Just looking at the numbers. The Butler, which at 47K ohms is the sweet spot, where the McIntosh is too low (20K), and the CJ and McCormack too high (100K)?
    pitdogg2 Posts: 27,448
    Well you should be blowing your ears off with the CJ then, should be well above 100db. If I'm looking at this correctly.
    How do those MIT network boxes work? Do they go by impedance or low, med, hi ?
  • verb
    verb Posts: 10,176
    maxward wrote: »
    Thank you! So here are your specs:
    22k each, so 44k ohms total?
    verb wrote: »
    I do not think it works that way why would it not be 22k?
  • verb
    verb Posts: 10,176
    Yep. Here's a stock pic:
    Mine were set to Mid.
    Set to low now?
    Looks like you need high for the mac then correct?
  • verb
    verb Posts: 10,176
    verb wrote: »
    Just guessing here, but since they're connected to the same output circuit in the pre?
  • verb
    verb Posts: 10,176
    Set to low now?
    I didn't play with it, but will tomorrow! :smile:
    verb wrote: »
    verb wrote: »
    Hmmm ok I figured with a stereo they would be the same output impedance left/right so in mono's it would still be seeing the same
  • verb
    verb Posts: 10,176
    For reference, here's the specs on the Joule.
  • verb
    verb Posts: 10,176
    verb wrote: »
    verb wrote: »
    Could very well be. I know Jeff @indyhawg was also running an Odyssey amp (not sure which model) to the Joule and had similar issues. Looks like their entire lineup is at 22k ohms.
    Thinking about this more, aside from the impedence issues. Do you have 2 volume controls in the mix ? One maybe for the source like a streamer and possibly one on a dac ? Since it is a line stage with no volume control ,was just wondering.
  • verb
    verb Posts: 10,176
    tonyb wrote: »
    Yup - Maxed out the volume on the Cambridge. The EAD transport does not have a gain adjustment. Not sure about the NS DAC. I need to check that. Thanks Tony!
  • jbreezy5
    jbreezy5 Posts: 1,141
    “Well said. The game to me is all about aspiration. Yeah I aspire to own someday a PASS, or VAC, or even MBL! Ya never know! :smile:
    And if I really hit it big, maybe some of the beautiful stuff @DSkip offers! :smile:
    verb - As a quick side note, I had the best experience ever in audio customer service, when I bought a Pass Labs X250.5 from Reno Hifi’s, Mark Sammut.
    He made me feel like a first class client before I even purchased, and buying used from him is the best way to get into Pass gear, IMO. MUCH more affordable than new and still get a warranty. Usually the gear is very minty, and he rates it conservatively and provides photos.
    You’re welcome, and I’m sorry. 😉
    ...and now back to the JOULE!
    one more thing since you posted the pic of the rear and jogged the old memory, the IC's going to the amp, trying plugging them into the tape and on the front input selector, switch accordingly and see what happens.
    I seem to recall I used it that way because I liked the sound better. Just an fyi...
  • verb
    verb Posts: 10,176
    tonyb wrote: »
    Thanks Tony! I'll give it a spin!
  • verb
    verb Posts: 10,176
    Work's been crazy @tonyb so I have not tried that yet. Definitely will try before I put the Cary back in! :smile:
  • maxward
    Try this with some caution. Tape output is likely fixed (not impacted by volume/gain control).
  • verb
    verb Posts: 10,176
    edited March 2020
    So today is Saturday, despite being inside all week, working from home, today is the day I paired the Joule with the Marsh amp.
    My hopes are that since the input impedance on the Marsh (56k) is less than all the other amps I have (100k) in the house, this may improve the output.
    In the secondary rig. Running 1C's through the Marsh, and a Marantz CD6006 as the source.
  • verb
    verb Posts: 10,176
    Well, I believe I'm on the right track. I now hit consistently 100 dbA peaks, as compared to the previous parings of only mid to high 80's! :smile:
    The Bulter, which has input impedance of 47k ohms, may stretch it a bit further, according to the folks who have shared their experiences (@tonyb, et al).
    Perhaps the Legacy Khartago mono's (22k each), is another good pairing too. Thanks again for your feedback @maxward .
    I'm gonna let the Joule warm up for a while longer, and run some more measurements. Right now, pretty happy, as I rarely play the system at such a high level anymore! But it looks like the Marsh plays pretty nicely with the Joule.
    This is so far, an interesting experiment. Thanks again to @daboyz for selling me the Marsh!
  • verb
    verb Posts: 10,176
    Oh yeah, I was only able to run the experiment for about 30 minutes, then the Mrs told me to turn it down! :smile:
  • indyhawg
    indyhawg Posts: 1,676
    Glad to see you have found an amp that matches up well with the Joule.
