PSW404 connection?
outlander
outlander Posts: 218
What do you guys think would be the best way to connect my sub subwoofer to my system. The following are the speakers and receiver I have to work with.
Mains = Monitor 10B’s, set to large
Center = CSi40, set to small
Rears = FXi30, set to small
Sub = PSW404
Receiver = Yamaha HTR-5250
Currently I have the sub hooked up to the receiver with a single shielded RCA cable running from the sub out of the receiver to the LFE in on the sub with the sub crossover frequency set to the max. (180Hz). It sounds fine but I keep hearing / reading the sub should be connected to the left and right main line out’s from the receiver to the two line ins on the sub.
Thanks!
O
Post edited by outlander on
    VR3 Posts: 29,696
    edited January 2005
    lfe cable
    80hz xover
  • Airplay355
    Airplay355 Posts: 4,298
    edited January 2005
    unless you go from the LFE out to the RCA ins with a y splitter....only choice i have
