What Should I Do Next?
jbreezy5
jbreezy5 Posts: 1,141
edited February 2020 in 2 Channel Audio
Hi All, I recently posted about my Yamaha KX-530 blowing a fuse...
jbreezy5 wrote: »
jbreezy5 wrote: »
The good: I put my Yamaha K-902 in the bedroom system today and it sounds great! 😀
The bad: I did the above, because my Yamaha KX-530 seems to have gone to cassette deck heaven, judging by failed electronic response and the subsequently smoky scent that follows it. This means no more remote control and track-to-track search convenience. 😢
...and sometimes a guy gets lucky! Popped the top of the KX-530, and it looks like just a blown fuse.
For those who are fans of guts and explosions (exceedingly small 😁) here are some pics:
marvda1 wrote: »
now the question is what blew the fuse.
Well, I tried a replacement fuse, and immediately upon pressing the power button, danged if the same thing didn’t happen!
Anyone know how to diagnose the problem and steps to fix?
    mhardy6647 Posts: 35,021
    Something is shorted upstream of the fuse (I assume that's the "mains" fuse?).
    Most likely culprits, IMO, would be the rectifier(s) -- probably either a full-wave bridge or four discrete power diodes, the main power supply filter capacitors, or, perhaps (and most vexing), a shorted winding in the power transformer.
    If it is none of those, it could be pretty much anything, but it's almost certainly a shorted component.
    One thing that's always possible is a "trivial" short circuit -- two connectors touching someplace, or a bare spot on the power cord inside the component that's shorting to ground or some other place it shouldn't be. Careful visual inspection is always in good taste.
    If there's a dead short, you should be able to find it with a DMM and some patient sleuthing, working backwards from where the power cord's leads connect to the power supply.
    The nice folks at hifiengine have the SM for this deck; the schematic's not too clear, but could be helpful You can see the power supply section on the lower right.
    https://www.hifiengine.com/manual_library/yamaha/kx-530.shtml
  • jbreezy5
    Ty sir!
