Simple sda 2b tl upgrade question
13»
    F1nut Posts: 52,380
    2.7 ohm 12 watt. http://www.soniccraft.com/product_info.php/27-ohm-vishay-mills-mra-12-p-4636
    You want a 0.5 ohm not a .22 ohm. The 0.5 ohm is only available is the 5 watt version. http://www.soniccraft.com/product_info.php/050-ohm-vishay-mills-mra-p-4610
    F1nut Posts: 52,380
    No, the 0.5 ohm resistor is used to compensate for the resistance of the polyswitch when you remove it.
  • Unknown
    edited February 2020
  • Unknown
    F1nut Posts: 52,380
    It's a thermal reset device. As it gets tripped it begins to degrade and trip more often.
