Uploading photos
I've tried every way I can think of to upload photos to posts on this forum. It doesn't seem to matter which browser, platform, image type, or image size I try I always receive the message "the file failed to upload." I've even tried to use several photo sharing sites to host the images, and that fails too. Is something wrong with my account?
PS Audio Stellar Gain Cell DAC/Preamp
Denon DVD 2910
Quad 12L Active Monitors
Marin Logan Dynamo 700W
    pitdogg2 Posts: 26,980
    Worked for me 😁
  • jdjohn
    jdjohn Posts: 3,330
    No need to link to a cloud service. Wherever desired in your post, just click on the little 'Landscape image' icon (mountains and sun) to 'attach image', then navigate to said JPG file, insert, and post.
    Tony M Posts: 11,596
    edited January 2020
    Your pictures might have too many megapixels.
    Try taking your picks in PC mode or something like that. Others with Computer skills will weigh in with knowledge of file sizes.
    Good luck.
  • aiconn
    aiconn Posts: 277
    jdjohn wrote: »
    That's the first method I tried. I just tried again on my work computer and got the same result. I'm convinced it's something with my account.
    Denon DVD 2910
  • aiconn
    aiconn Posts: 277
    Tony M wrote: »
    Good luck.
    I've tried with photos from my phone, photos copied from the internet, and screen captures on my PC. The latter was 59KB, and the resolution was 563x259. Still a no go.
    Denon DVD 2910
    Picture I posted above came straight from phone, mobile is 95% of my use here. @jdjohn is correct in that you click on that icon and go from there. I've never had any problems with several phones and 8-10 different browser from the google play store. I've used Armorfly, Mozilla and edge mostly.
    msg Posts: 10,452
    Yeah, which browser are you using, and is it the same across all computers you're using?
    If scripts are blocked somehow, that might cause this behavior.
    I don't have a smart phone, only a smart PC. :D
    If I want to post a picture, I open 2 window ports.
    1...polk audio, and the thread I want to post in. I type what I want and then leave the blinking little box...BELOW the words.
    I then click on the second window port. I can go anywhere on there. The web, my saved photos on my PC and when I find a picture I want to post, I RIGHT CLICK inside the picture. 98% of the time an info box pops up and asks 10 or so things. One of them is "Save picture". I LEFT CLICK those words.
    I then click back on the Polk Forum window. It pops up now with that little black box still blinking.
    I LEFT CLICK the box and that connects me to that spot again. I then RIGHT CLICK and hit paste.
    NOW...….the Polk Forum has to download the info and you'll see a short scrolling bar rolling across the top of the Polk thread box you're in. It takes a second, maybe 5, and then...POP, the info of the link to the picture or video will appear.
    Pics say "img" at both ends of the picture info, under your typed words.
    videos say something else. I don't remember right now. :(
    I think I have that right. :#:)
    try, try again.
    Good luck again.
  • jdjohn wrote: »
    This worked for me.
  • aiconn
    aiconn Posts: 277
    I've tried all the things mentioned with multiple browsers on multiple computers and phones. I now convinced that something is wrong with my profile. I guess I'll create a new account to see if that resolves my problem.
    Denon DVD 2910
  • jmwest1
    jmwest1 Posts: 18
    It works with a new profile!
    Denon DVD 2910
    mhardy6647 Posts: 34,944
    aiconn wrote: »
    jmwest1 wrote: »
    Wait, did you come back with a new identity?
    More to the point, I guess... are you all set now?
    If so, huzzah! :)
    (just a random post using the 'attach image' button in the message editor window :p )
  • aiconn
    aiconn Posts: 277
    Yep. It works with a new profile. I guess I'll have to start using the new one. :s
    Denon DVD 2910
  • What's hiding under that cover @Tony M ?
    AMX Javelin... :D
    My beloved 95' F150 w/36K miles on it so far.
  • No offense Tony M but I was hoping for the AMX Javelin.
    I was gonna posit that it was a gussied-up Yugo.
    One of the 2 guys who visited the other day thought I had a race-car under the tarp.
    And he's seen my truck parked there for a year since he's been coming around with Mr. Paul. But it wasn't covered until the leaves started falling.
    audioluvr Posts: 5,892
    aiconn wrote: »
    A lot of companies use an IT security service that prevents posting on the web. That was your first mistake 😂
