Power for SDA2 A
jacobmeyerammo
Ok guys, you've given me ALOT of useful info on what speakers i have to how to upgrade them and so on. Now my question regards...what is going to power these things without blowing up everything including the wallet. Ive got a 7.1 receiver for surround system but plan to listen to the SDA S as pure stereo. I listen loud. Not any one genre of music but a hodgepodge. Any recommendations for an amp that can handle spl on a budget?
Best Answer
jacobmeyerammo wrote: »And sorry pittdog2...noob again. How do i check pms on this forum?
Click on the envelope icon under your name in the upper right corner.Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
Answers
Depends how budget is budget.
Older used...
B&K reference 200.2
Parasound hca1500
McCormack dna 1 or 0.5
Adcom (I’ve not heard)
Outlaw (I’ve not heard)2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Budget?
I would be pressed to go more than 1200... I dont want to go the straight pro audio route but they make it quite easy so it seems.
If i have learned anything its that i will need a ton of current. I cant find any solid numbers as far as wattage but down around the 3 ohm figure?
I was unable to find a B&K 200 near me and the reviews of the parasound say they dont do well with low ohm pulls.
location?
Adcom 5802 ? -
Wisconsin USA
PM incoming
The adacom 5802 seems like a great amp. So far one for sale...in Denmark 🇩🇰...cant read the ad to know if they will ship it.
you on a computer? or mobil
Hey where about in Wisconsin? I’m in Wisconsin Dells.
That parasound has high current and did wonders for my 2a’s never broke a sweat. But for $1,200 you can do much better for sure.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Norteast....just below Green Bay right on the big puddle
That Parasound HCA 1500 amp, which is discontinued, has 60 amps peak current capacity per channel and is rated for 4 Ohms and Polk calls your speaker a 5 Ohm speaker. Remember, the speakers you have only dip briefly down to 3.5 Ohm impedance for a very small range (and I believe it is mostly resistive load) in the bass region according to that review with measurements I posted in the other thread.
https://parasound.com/vintage/hca1500a.php
And here's one that is accepting offers on eBay:
https://www.ebay.com/itm/Parasound-HCA-1500A-2-Channel-Power-High-Current-Amplifier-/264582456436?_trksid=p2349526.m4383.l4275.c4#viTabs_0George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
I’m not that far from you. I sent you a PM. Check your message inbox
