Would I benefit from new wire/cables?
lunazul
What?2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Yes absolutely! You need to upgrade to some Albanian Skin Effect wires.
https://parttimeaudiophile.com/2016/09/20/the-far-corners-the-skin-effect-and-albanias-organike-cables/
And they should smell good too! -
Sorry I only got as far as the meat stick...Gustard X26 Pro DAC
You could definitely upgrade those. Both Douglas Connection and Audioquest offer upgrade tiers for hearing enhancement devices.
Dynamat the shells and mass load with lead shot for tighter sound and better isolation from ambient interference.
Swap earpieces for Permatex “The Right Stuff” form-in-place gasket for permanent custom fit.
Each of these makes a noticeable difference. I’ve seen it a million times.I disabled signatures. -
Is this a common problem for you? Just cant get past a meat stick?
cables don't matter
Three 20 amp circuits. -
In a manner of speaking.....YESGeorge / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
New wires or cables won't help.........But you should strongly consider going from SS to tubes.
Crossover rebuild will help as well. A Dreadnaught will take things to a completely different level. Check with VR3 for a Monastery Level III crossover and you will be set for life.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
