Would I benefit from new wire/cables?
  • dragon1952
    dragon1952 Posts: 4,931
    What?
  • CH46E
    CH46E Posts: 3,595
    Yes absolutely! You need to upgrade to some Albanian Skin Effect wires.
    https://parttimeaudiophile.com/2016/09/20/the-far-corners-the-skin-effect-and-albanias-organike-cables/
    And they should smell good too!
    audioluvr Posts: 5,990
    Sorry I only got as far as the meat stick...
    msg Posts: 10,475
    You could definitely upgrade those. Both Douglas Connection and Audioquest offer upgrade tiers for hearing enhancement devices.
    Dynamat the shells and mass load with lead shot for tighter sound and better isolation from ambient interference.
    Swap earpieces for Permatex “The Right Stuff” form-in-place gasket for permanent custom fit.
    Each of these makes a noticeable difference. I’ve seen it a million times.
  • CH46E
    CH46E Posts: 3,595
    audioluvr wrote: »
    Is this a common problem for you? Just cant get past a meat stick?
  • Willow
    Willow Posts: 11,266
    cables don't matter
  • BlueFox
    BlueFox Posts: 15,250
    Willow wrote: »
    cables don't matter
    At least not for the OP. :)
  • Gardenstater
    Gardenstater Posts: 4,804
    In a manner of speaking.....YES
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • delkal
    delkal Posts: 764
    New wires or cables won't help.........But you should strongly consider going from SS to tubes.
    nooshinjohn Posts: 26,002
    edited January 2020
    Crossover rebuild will help as well. A Dreadnaught will take things to a completely different level. Check with VR3 for a Monastery Level III crossover and you will be set for life.
