Another tube question
While shopping for tubes,I noticed that 12ax7's command a higher price than 12at7's. Is this simply supply and demand,or is there more to the story?
Thanks in advance,
Ray
  • marvda1
    marvda1 Posts: 4,939
    6dj8's even more expensive.
    Puritan PSM156
    heiney9 Posts: 25,406
    edited January 2020
    Supply and demand.....mostly demand. 12AX7 were used a lot more. Also in guitar amps as well. Also there is probably more "mystic" (for lack of a better word) attached to the 12AX7 since it was/is more popular.
  • TEAforONE
    TEAforONE Posts: 1,035
    heiney9 wrote: »
    Thanks for the answer.
    mhardy6647 Posts: 34,922
    edited January 2020
    The 12AX7 has a high enough amplification factor for use as a moving magnet or tape head (pre) amplifier -- it is not so straightforward to do that with a 12AT7 or a 12AU7 (multiple gain stages would be required).
    Personally, and strictly FWIW, I am not much of a 12AX7 fan for anything -- much less 6922s -- their Octal cousins get my vote :)
    12AU7 and 12AT7 can make very decent driver stages (voltage amplifiers) in tube amplifiers, FWIW (although I still kinda sorta prefer their octal colleagues).
    Speaking of which - and distressingly but not unpredictably off-topic - here're a couple of interesting pieces about the history of the 6SN7 (a personal fave in terms of medium mu twin triodes) -- strictly FWIW, of course.
    http://vinylsavor.blogspot.com/2014/02/tube-of-month-6sn7.html
    http://www.fourwater.com/files/hist6sn7.txt
    The octal "equivalent" (ish) of the 12AX7 or 6922 would be, e.g., the 6SL7 (amplification factor = 70)... the real 12AX7, of course, has an amplification factor or 100. :|
  • headrott
    headrott Posts: 5,496
    edited January 2020
    12AX7's are a very common tube, yet there are certain brands and the way they are made that make for a high demand and high cost tube as the "good ones" or "best ones" haven't been manufactured for about 40 to 50 (+/-) years now.
    You can get current manufactured 12AX7's (typically ade in Russia) for relatively cheap. However, they don't sound nearly as good (especially in the tonality department, and probably the soundstage too) as the older 50's and 60's 12AX7's. There are preferred brands and tube designs even in the 50's and 60's tubes too.
  • TEAforONE
    edited January 2020
    Mark,Why don't you care for 12ax7's? Too much gain?
    edited January 2020
    Just, to me, there are better sounding twin triodes (or single triodes, as the case may be). The 12AX7 or 6922 is OK for phono/mic/tape head preamp use, but (strictly IMO) they're not a great choice for use as drivers or phase splitters.
    They were cheap and plentiful in their time, and vintage amplifiers ('specially cheaper ones) tended to be full of 'em. I think my EICO HF-85 (stereo full-function preamp), e.g., has... umm... five of em. Yup, per Sams 482. Ten high mu triode sections in toto in that bad boy. :)
    Make no misake: miniature tubes do have real advantages for high-frequency (e.g., radio and TV) signal applications, but not so much for audio-frequency components.
  • verb
    verb Posts: 10,176
    Wow Mark, I counted 3 "FWIW" in that post. IMO, very informative and interesting! Thank you, FWIW :smile:
    treitz3 Posts: 19,948
    Talk to me about these "octal cousins" if you don't mind. What in the heck do they do differently?
    edited January 2020
    Give a listen.
    To me, circuits using the octal twin triodes (or single triodes, like the 6J5, or even their 4-pin forebears, like the 76 or 27) (EDIT) generally just... sound better.
    More like real music, which is what I look for in this furshlugginer hobby.
    YMMV, of course.
    Thus all the FWIWs before -- just my opinion(s), you know?
  • marvda1
    here's what deHavilland had to say on a q&a about the 6sn7 tube.
    Q: And the 6SN7?
    A: The 6SN7 is a tube that SE people describe as having "Big Tone". It is a dual triode that has a very open, relaxed and graceful sound, without sacrificing detail. Introduced by RCA in 1939, it is hard to find a driver tube that is more rugged, and sonically consistent.
    Puritan PSM156
  • verb
    verb Posts: 10,176
    Give a listen.
    YMMV, of course.
    Interesting Doc. So I did a quick search, and they do make adapters for the 9 pin miniatures to octal. Have you tried that?
    marvda1 wrote: »
    Q: And the 6SN7?
    That sounds good to me.
    pitdogg2 Posts: 26,939
    edited January 2020
    Well are those 12xx7's getting 12 volts the the heater? How do those adaptors nagate that extra 6 volts too much?
    Asking for a friend
    edited January 2020
    verb wrote: »
    Give a listen.
    YMMV, of course.
    that's kind of like adapting a 1.5 liter turbo 4 into a car currently sporting a 5 liter V8 (or vice versa). I mean... you can...
    Now, there are tubes that are identical except for their envelopes -- the 6AQ5 and the 6V6 power tubes for example; swap the pinouts and sockets and they're essentially interchangeable.
    The B9A base twin triodes are all sorta interchangeable with each other*, and they generally have (for lack of a better word) cognates in 8BD base twin triodes, but AFAIK most if not all are apples to apples. In other words, a 12AX7 isn't a 6SL7 in a 9 pin miniature envelope. The 8BD twin triodes are (mostly) sorta kinda interchangeable, too, but that doesn't mean that, e.g., a 6SN7 is going to work
    properly in place of a 6SL7 -- even though it'll probably work in some sense of the word.
    Also -- don't forget about filament current requirements :)
    EDIT: The 6SN7 did chase into a couple of 9-pin 'cognates':
    https://en.wikipedia.org/wiki/6SN7#Successors_to_the_6SN7
    6SL7 gets a little more complicated (i.e., I don't know nothin' about this/these)
    https://www.diyaudio.com/forums/tubes-valves/329556-6sl7-equivalent.html
    https://www.diyaudio.com/forums/tubes-valves/15430-single-section-equivalent-6sl7.html
    apparently the 5751 is pretty similar operationally to the 6SL7:
    https://www.audioasylum.com/audio/tubes/messages/23/235913.html
    ______________
    * here's my handy little table of B9A tubes that I am typically interested in, e.g.:
    Asking for a friend
    Don't forget that the 12V filament in a 12AX7 (B9A-base) tube is center-tapped; the filaments can be operated in series or parallel, which is why (I think) you'll find 'em in components that otherwise are otherwise all 6V tubes (except -- often, of course -- the HV rectifiers, which use 5V filaments).
  • verb
    verb Posts: 10,176
    Doc you are walking tube encyclopedia! Thank you! I’ll stick with the 6SN7 to 7N7 (IIRC) adapter! :smile:
  • TEAforONE
    This is way above my pay grade. I'm trying,though!
    Well... I mean, if you have a component that uses 12AX7s... stick with 12AX7s :)
    It's not like there aren't good ones... it's just that you'll pay for 'em.
    Personally, I am happy enough with good ol' US made 12AX7s from the 1950s or even '60s. Not top echelon, but you won't have to sell a kidney to buy a quad of 'em, either.
    If you can give up a little oompf, though, you can always try 5751s.
  • TEAforONE
    These tubes are for my Aric Audio preamp. The way Aric designed this,the end user can roll,in 12au7's,12at7's,and 12ax7's. So,I've been playing with rolling signal tubes. That is why I was curious as to the higher prices for 12ax7's. The next tubes coming in are a pair of 1957 RCA black plate 12au7's,and a pair of RCA long gray plate clear top 12au7's.
    Also of note,this pre has a gain adjustment on the rear. This comes in very handy when I rotate amps.
  • Faustin
    Faustin Posts: 1,151
    [/quote]
    [/quote]
    I as well have an Aric Audio Transcend preamp with a phono stage. When I purchased it from the previous owner, it came with 12at7's in all positions. I had it coupled to Bottlehead Paramount 300B monoblocks and single driver full range speakers. Since the pre can use several varieties of 12a tubes, I didn't give it much thought. I did roll in some other 12at7 tubes from my stash, but I really was not liking the sound of the setup at all. Didn't know if it was the pre, amps, speakers or?? Used the speakers with a rebuilt Fisher X-100 and that setup sounded great. I was ready to just sell the amps thinking that the 300B sound was not for me. Then for some reason I decided to swap out the 12at7's for some 12ax7's. It was a stunning change. People talk about the drastic changes by rolling different manufacturers tubes, but to be honest with you, most of the time I am not hearing a big difference. This though, was so different. Before the sound was thin and sometimes shrill on the high end. I was blown away by the change.
    Before I swapped the tubes, I had been corresponding with Aric about some general info about the pre amp. When I shared my tube swapping experience with him, he indicated that he really designed that pre around the 12ax7 tube. Others flavors will work, but.......
    On a side note, the Bottlehead Paramounts use a 5670 (396a) tube. The later version can use a 6sn7 in place of the 5670. Through the BH forum, I found some nice adapters which allowed me to roll in 6sn7 tubes. Richer, open sound.qhm3jy1elxhw.jpg
