3D printed SRS Badge
mzisman4
mzisman4 Posts: 16
edited January 2020 in Vintage Speakers
I'm a long time lurker and finally have something worth sharing.
I picked up a set of SRS 2.3 that were missing one of the grill labels. I haven't seen any on eBay so I decided to design and print a placeholder. Pictured example was done in PLA with a 0.3 nozzle.
update: The contrast of the gold was too noticable. One light pass of espresso stain (pen) and wipe immediately dampened the color enought that I cannot tell the difference from my regular listening spot. Still planning to print at 0.2 to clean up the details
With 0.4, the SDA words were illegible. I plan to print with 0.2 once more filament comes in. The gold is too bright so I'm also planning to source a more bronzed metallic filament.
Thingiverse link is coming soon.
Post edited by mzisman4 on
    F1nut Posts: 51,763
    What are you posting a link to???
  • vmaxer
    vmaxer Posts: 5,120
    To the badge information.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    F1nut Posts: 51,763
    vmaxer wrote: »
    Ok, checking it wasn't yet another spam link.
  • verb
    verb Posts: 10,176
    Cool stuff @mzisman4 ! Post some more pics once the thinner filament comes in!
  • Gerres26
    Gerres26 Posts: 874
    I’ve been wanting to get the badges for my 1.2tl’s re-done for a while. I was thinking of going opposite the oem color scheme and have them be solid polished brass with black writing/engraving... just haven’t found a place to do it yet, although I haven’t been trying hard to be honest.
  • verb
    verb Posts: 10,176
    Gerres26 wrote: »
    @Toolfan66 Larry didn't you have some custom badges made? IIRC :smile:
  • HzTweaker
    HzTweaker Posts: 959
    mzisman4 wrote: »
    3D printing is very cool technology! I did a favor for a friend some time ago and in return he printed me some spike cups for my speaker stands (at 50% fill).
    Very cool, keep posting your updates as you progress.
  • RobbyKY
    RobbyKY Posts: 117
    I love 3D printing but have you considered going with a rubber mold and casting a replacement in resin? Maybe a little biased since I'm set up to do this for another hobby of mine but very simple using products from a company such as Smooth-On. (Give them a Google) I have all the goodies like high pressure chamber for casting and a vacuum chamber for degassing the silicon but these really are not needed for a basic shape.
    Make a silicon mold of the original and then use any of a wide range of resins that are available based on "engineering" needs. The badge could use basically anything while something like the spike cups would need a higher strength chemistry with a filler to support the pinpoint weight of a speaker over time. With minimum effort, you would get an exact replica with little to no post finishing work. The process will even pick up fingerprints on surfaces if you forget to wear gloves so the accuracy is crazy. Cast the badge in black and then use a gold paint pen to pop the highlights. If you get a wild hair and want to go radical, you can color the resin in something like red and then outline the lettering in black.
    Once you have the mold, you can kick out duplicates about every 15 minutes for a simple design. Smooth-On has outlet stores in many big city areas to save on shipping. Down here in Dallas I get my supplies from a place called Reynolds Advanced Materials close to DFW.
    Media Room: Parasound JC-5, Cambridge 851N, Schiit Freya, SDA SRS 1.2tl
    Game Room: Carver M4.0t, Carver C-4000, Oppo BDP-105, SDA SRS 1.2tl
    Bar/Card Room: Carver TFM-55, Carver C-1(BillD), Oppo BDP-93, SDA SRS 3.1
    Son's Room: Carver TFM-55, Carver C-1(BillD), Laptop/AQ Dragonfly, SDA SRS 3.1
    Bedroom: McIntosh MC150, Cambridge CXN, SDA 2Btl
    Outdoor Pool Area: Yamaha R-N803 with four Polk Atrium 6
    HT: Polk RTi A9s, CSi-A6, RT-65, RTi-A3's, Marantz SR5012, XPA3, UDP-203, Epson 5040UB
  • @RobbyKY That sounds like I great idea but it's pretty far outside my comfort zone. I went with 3D printing because it's what I have and it seemed like a reasonable project. Not quite ready to jump into a new rabbit hole!
    I think my little 3D printer is nearing it's limits in terms of resolution somewhere around .3mm and .2mm. I'm playing with a few more settings but the benefits of the smaller nozzle were negligible at best the first time around.
  • Aboone
    Aboone Posts: 1
    Thanks for the badge, I had my daughter paint the lettering with a gold craftsmart pen and it turned out great!5vd54w5sp6qp.jpg
