Die termites, die
Had a vendor by today, and confirmed termites in a ceiling beam. I knew that since it also happened ten years ago. The last time they used orange oil, but this guy said they will use some chemical. Fine, as long as it works. The main thing is the chemical is injected into the wood. I will not have a whole house fumigation with a tent.
  • Milito
    Milito Posts: 1,909
    Good luck.
    Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables.
  • motorhead43026
    Are they dry wood termites?
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
  • BlueFox
    BlueFox Posts: 15,251
    I guess. They are in the inside ceiling beam, which is always dry.
    treitz3 Posts: 18,313
    Bud, something is attracting the termites to your home. My guess would be water, especially since it has happened twice in 10 years. Check your moisture level in ANY area of the home and pay attention to leaks in or around your hot tub, gutter drainage and crawl space. Target moisture level is 15% or less. (less is even more)
    Moisture level meters are relatively cheap, FYI.
    Did you not have a termite bond on the home after the last infestation?
    Also, how close are your neighbors to your home?
  • BlueFox
    This is California. Termites love the dry, hot weather. Being 70, I can live with this every ten years or so. :)
    I can't help you if you don't answer the questions.
    If you can deal with it? Happy droppings.
    F1nut Posts: 49,792
    It's California, termites run rampant.....seriously.
    xschop Posts: 4,684
    California termites are always looking for a free lunch.
  • Mikey081057
    Mikey081057 Posts: 7,127
    BlueFox wrote: »
    Unless you get a wooden leg!
    Garage | Polk Monitor 5B's
    mhardy6647 Posts: 33,027
    I remember seeing the houses with big ol' tarps/tents around them when we lived out there.
    Termites are (can be) a big problem in Califonia :(
  • BlueFox
    Yes, that is a common sight. You have to live somewhere else for three days when your house is tented. Fortunately, the critters here are only in a ceiling beam. They inject the poison into the wood, and it only causes little holes that are easily patched.
    Viking64 Posts: 6,678
    SAVE THE TERMITES!!!!! :'(
  • tophatjohnny
    tophatjohnny Posts: 4,163
    Cally Termite Lives Matter.
  • Mikey081057
    Call Russ @lightman1 to visit and unleash a legume MOAF on the vermin
  • Willow
    Willow Posts: 10,871
    In German it means The Bart, the....
    msg Posts: 9,428
    Moisture or Magico speakers they're drawn to. One or the other. I've seen it a million times.
    Willow wrote: »
    But... auf Deutsch, that'd be feminine Bart
    Der Bart is something else altogether :)
    In fact...
    Ich habe ein Bart.
  • verb
    verb Posts: 10,176
    Interesting site. Gute informationen hier :smile:
    https://www.orkin.com/termites
  • OleBoot
    OleBoot Posts: 2,105
    Willow wrote: »
    In fact...
    Ich habe ein Bart.
    Sie haben mehr Haare im Gesicht als auf dem Kopf.
    msg Posts: 9,428
    edited January 2020
    Oh yeah? Well oonta gleetin glountin globen!
  • BlueFox
    Looks like the termites are now posting. I’ll be glad when they are eliminated this coming Monday. :)
  • OleBoot
    Us termites get seriously misunderstood.
  • Mikey081057
    OleBoot wrote: »
    Willow wrote: »
    In fact...
    Ich habe ein Bart.
    Das ist ja richtig. :p
    The interesting thing about termites is that it's their gut flora that allow them to do what they do to wood.
    https://www.sciencedaily.com/releases/2018/02/180216110530.htm
    Finally, I'll leave this thread with a nod to the great Baltimorean/poet, Ogden Nash.
    The Termite
    A primal termite knocked on wood
    And tasted it, and found it good
    And that explains why Cousin May
    Fell through the parlor floor today
  • BlueFox
    The termite exterminator just left. Pretty easy job from his perspective. A few tiny holes in the beam, inject the poison, patch the hole, and add a drop of touch up paint. Hopefully this is good for another 10 years.
    Glad to hear, Bud.
  • verb
    verb Posts: 10,176
    Yep. Nice to know the ceiling structure resonating while playing metal won't cause a collapse! :smile:
  • verb
    verb Posts: 10,176
    Willow wrote: »
    In fact...
    Ich habe ein Bart.
    Sind Sie das, herr Hardy? :smile:
  • motorhead43026
    ^^ who is that? Looks like a stump full of pissants.
