DIY Audio Rack
hochpt21
hochpt21 Posts: 5,423
edited December 2019 in DIY, Mods & Tweaks
I am far from an experienced craftsman, but I’ve really wanted to try my hand at one of these flexible racks for quite some time.
I used 3/4” white pine plywood, 3/4” black oxide threaded rod, and spray painted the rest of the hardware black. Ended up using a stain/poly combo. Probably spent about 13 hours all said.
I know there are many experienced folks on here who do amazing work on projects like this, but I’m actually really happy with how it turned out!
Thanks for listening,
Paul
*****Edit...the photo uploader scrambled the order of the photos, but you get the idea.
  • hochpt21
  • hochpt21
  • hochpt21
    msg Posts: 10,452
    Dag, Paul, that turned out great!
    I've been wanting to build one of these for a while, too.
    Where did you source the hardware and wood? Big box store?
    Where did you use the filler?
    What grade ply is that? Was it just the nicer sheet stuff, or a woodworking grade of some sort? I haven't done any sort of woodwork before, so I don't know where one gets material and what is appropriate to use.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    The best part of a Flexi style Rack is the you can design and build about any configuration you want/need.
    Nice Work!
  • dromunds
    dromunds Posts: 10,123
    Where’d you get the black paint? >:) Really nice. 33 1/3.
  • jdjohn
    jdjohn Posts: 3,350
    I like it!
  • joecoulson
    joecoulson Posts: 4,943
    Very nice job. Well done.
    Now where do I place my order?
  • hochpt21
    msg wrote: »
    The plywood is from Home Depot. I went with the $35 sheet white pine. Looking back maybe opted for the $55 sheet oak.
    The hardware from Amazon was FAR less expensive than HD. The threaded rod I actually found on Amazon as well. I didn’t care for the regular steel finish from HD, so I found this black oxide finish, which is actually like a dark gray/silver. I like the contrast with the black hardware and the stain.
    The filler was for the nail holes that were counter sunk. And I used a little bit for the edge of a couple boards. HD ripped the boards at 19” for me, and he was a little rough with the first cut.
    It was my first time doing most of this kind of stuff.
  • hochpt21
    dromunds wrote: »
    I had the can of spray paint, but I don’t remember buying it. Maybe it’s magic after all?
    Thanks, I replaced this with a VPI Scout in the main system, but I could happily live with the Pro-Ject. It was my first “real” turntable.
  • hochpt21
    Nice Work!
    Agree, I wanted something that sat low enough where I could see the table spinning. It was a fun project.
    I may attempt another one for the main system which would be more of a vertical build.
    msg Posts: 10,452
    Nice! Good info. I'm going to try to get one of these underway this Winter. I was thinking about a 3-bay version at one point, for use in the combo space to consolidate 2ch gear and at TV system. Not sure yet. It has to accommodate a 706 center and that speaker not be too high up, which is why I was thinking about the wider build. Need to do some maff.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Well done! It's always cool to complete a project like this and hear people say... You did that yourself?!?! Enjoy! :)
  • Faustin
    Faustin Posts: 1,151
    Very nice work. I really like the whole concept of the shelving. Pretty much make it almost any size to fit your needs.
  • CH46E
    CH46E Posts: 3,595
    Very nice job. Looks great. Bet its heavy!
  • DaveHo
    DaveHo Posts: 3,583
    Looks great! Love the black adonized rod.
  • aprazer402
    aprazer402 Posts: 3,384
    Great work! Clean (non-cluttered) setup. Very nice looking room!
  • xsmi
    xsmi Posts: 1,801
    Thanks for the inspiration. I've go to do something different because my power amp is 78lbs and I don't trust it on my glass shelves.
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • steveinaz
    steveinaz Posts: 19,545
    Very nice build!
  • Mike Reeter
    hochpt21 wrote: »
    When I had my Cronus powering the SDA's, it was a wonderful match up. I'm positive this setup sounds very good!
  • CH46E
    CH46E Posts: 3,595
    edited January 2020
    Is it just me or can no one click on the pictures to enlarge them? I used to be able to. Really annoying when trying to get a closer look at this awesome DIY!
    treitz3 Posts: 19,986
    Hover over photo. Right click on mouse, hit "View Image".
    Continuously pressing control, and scroll in and out as desired if you want even further close ups.
  • CH46E
    CH46E Posts: 3,595
    edited January 2020
    Thanks, but I'm usually on my phone rather than my PC.
  • codycatalist
    codycatalist Posts: 2,662
    CH46E wrote: »
    Android? Tap and hold the picture, open in new tab.
  • CH46E
    CH46E Posts: 3,595
    Bingo! Thanks man!
  • CH46E
    CH46E Posts: 3,595
    @hochpt21 how much would you say you spent on the parts alone?
  • hochpt21
    CH46E wrote: »
    $50 - Threaded rod
    $35 - Hex nuts and washers
    $40 - Wood
    $25 - Trim
    Then sandpaper, braid nails, wood glue.
  • mrbiron
    mrbiron Posts: 5,721
    hochpt21 wrote: »
    Go with the birch or maple. Oak is such an ugly wood. :s
  • hochpt21
    hochpt21 wrote: »
    I’ve only recently moved it down here. It sounds REALLY good. I do think that I’ve lost a decent amount of bass since I had the Parasound powering them however. Not sure if that’s because of the tube amp? Or maybe the bass is just tighter? I’m thinking about picking up a sub.
