Direct Electrical Line Question
  • aprazer402
    aprazer402 Posts: 3,386
    Looks to be very reasonable to me.
  • lightman1
    lightman1 Posts: 10,796
    Yup. Right on target. Plus beer.
  • stretchl
    stretchl Posts: 1,334
    Capital idea!
    - Isaac Asimov
    Hi-Fi
    Cabling by Groneberg
    Visuals
  • kharp1
    kharp1 Posts: 3,453
    I'm not Russ, but, I am an electrician. That looks reasonable. Why not run a 4th circuit at the same time. Cost is minimal doing it now.
    treitz3 Posts: 19,992
    edited December 2019
    Where is the charge for the permit? Is this guy legit?
    Also, 3 hours to install a sub panel? I take it that this includes a trip to the local strip bar on your dime.....?
  • stretchl
    @treitz3 I can’t imagine we’d need a permit for that work. No walls. No extra panel.
    @kharp1 I was thinking the same thing. What’s your reasoning? Thanks.
    - Isaac Asimov
    Hi-Fi
    Visuals
  • kharp1
    kharp1 Posts: 3,453
    Last sentence sums it up, the cost is minimal to do it now. You never know where you're journey will take you, you may not need it, but, better to add another hundred in parts, and not much more in labor, to the pot now, then have to pay 5 times that later.
  • tratliff
    tratliff Posts: 1,790
    Good advice. I went from my original 3 20 amp lines to an additional 2 when I decided to purchase subs.
    Much easier for me as I ran them all myself and already had a sub panel. But do consider what ifs for planning.
    stretchl wrote: »
    Call your local permit office unless you don't care. In my neck of the woods and where I have done construction, you need an electrical permit to add a sub panel. From what I understand and have heard, if it's not permitted and a fire breaks out as a result of that circuit? Insurance will not cover the loss of anything. Like I said, if you don't care (many people don't) all is well.
    We got popped for a stop order and the inspector demanded we pull an electrical and whole house permit on Baltimore reno a couple of years ago because he spotted a romex cable hanging outside of a trash can along with a used paint brush. All we did was lipstick on a pig with that reno, no electrical, plumbing or anything. Thank Gawd the reno was already done. Baltimore inspectors just LOVE to find BS reasons to pull a permit. You can't even sneeze up there without a permit. Or three.
  • stretchl
    treitz3 wrote: »
    stretchl wrote: »
    We’re not adding a panel
    - Isaac Asimov
    Hi-Fi
    Visuals
    Viking64 Posts: 7,551
    stretchl wrote: »
    Your estimate says you are.
    Ed Zachary.
  • stretchl
    Maybe there’s confusion bc he doesn’t say “Add 3 dedicated circuits from existing Electrical panel”?
    Or am I missing something?
    In any case, I’m happy to ask him about the permit. Seems like a straight up guy.
    - Isaac Asimov
    Hi-Fi
    Visuals
    This is a sub panel. In all of the areas I have personally done construction in, this requires a permit. Hence the inquiry.
  • lightman1
    Take a pic of your existing panel for me please
    stretchl wrote: »
    Yeah, you're missing something: The entire second half of your estimate. :p (The third and fourth parts.)
    3 hours labor @ $78.00/hr = $234.00.
    $187.00 for the 100-amp sub panel.
  • stretchl
    I think I understand what’s happening. He and I talked about the possibility of putting in a sub panel, but (as I understand it) it’s not necessary given the number of circuits a available in the current box. The two of us obviously need to get that straight before moving forward.
    Too many moving parts this time of year for me to keep up. So thanks for the gut check.
    - Isaac Asimov
    Hi-Fi
    Visuals
    I expect you will have a few people chime in and recommend the larger 10-gauge wire for at least 2 circuits, if not all of them.
    It may be that you only have room for 3 more circuits in your main (200-amp) panel. As myself and others have suggested, I would strongly urge you to run 4 circuits now.
    Also, the 100-amp sub-panel may go a long way in eliminating electromagnetic interference and/or grounding issues. Isolating the ground from that main panel would be a great idea and now would be the time to do it.
    If you have enough amperage available in your current panel, along with the space then a sub-panel is not necessarily needed. If that is the case, then he needs to resubmit another quote for you. If he is adding a sub-panel, then you will most likely need to pull a permit.
    lightman1 wrote: »
    I would advise doing this whenever you get the chance.
  • stretchl
    Thanks guys. Will share (some of) this thread w him. o:)
    - Isaac Asimov
    Hi-Fi
    Visuals
  • kharp1
    kharp1 Posts: 3,453
    Agree with the sentiments that a permit is wise. Where I live a homeowner can pull his own permit if he's doing the work. It is an added cost, but, I believe its worth the added cost when dealing with anything electrical. It's a lifetime addition that goes with the house. I also vote for the added sub panel and full size breakers instead of twins.
    I'm an industrial electrician, not a residential, dealing with mainly robot installations, so I'm not trying to upsell for the industry. It's just one of those things where the estimate as written is fair, and, not a place where corners should be cut.
  • gp4jesus
    gp4jesus Posts: 2,019
    kharp1 wrote: »
    I’m a DIYer. Nor sure about a permit for DIY but NEVER cut corners on safety. Not worth losing everything, or worse, ANYONE for a few bucks.
    Long story short: I’m “related*” to a commercial electrician. I had him inspect (critique) much of my inside work** and in a storage building. “It passed.”
    *its very complicated 🥴😂!
    **troubleshooting an extremely minor***?HT ground loop.
    ***barely heard
    I could go on but... I look forward to your “new system” review!
    Tony
    *all connected w/Premiere ICs
  • CoolJazz
    CoolJazz Posts: 572
    When you go into doing electrical circuits for audio, I would push two things to the top of the list...
    1 - Balance the load in the house as well as possible for the normal uses between the two phases (legs). (lowers the AC distortion products)
    2 - All circuits intended to run audio should come from the same phase (leg). Straddle and you're in for the buzz. (load imbalance will try to equalize through DC coupled device for sure!)
    Neither thing is really about cost except, and it seems likely in this case, the using one phase for all the audio feeds causing the addition of a sub-panel. Moving things a position or two in the box to balance the load some and to get available the same leg for the audio feeds is possible maybe and the result will be worth a little effort. 9 times out of 10, electricians don't understand the need for the same leg being used.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
