[Magnifi MaxSR]Why always HDMI2?
Raph
Raph Posts: 3
edited December 2019 in Troubleshooting
Hello everyone!
Sorry if the question was asked but English is not my native language and I have broken the head to force translate :-)
I don't understand ... HDMI1 there is set top box from my TV supplier and HDMI2 there is the Nvidia Shield.
-Shield on, I put HDMI1 => impossible. back to HDMI2.
-Shield on Standby == >> also impossible. back to HDMI2.And it turns the Shield back on
If I want to watch TV, I have to turn off the Shield. The Shield is in a cabinet it is complicated to disconnect / reconnect the plug.
Do you have an idea of the problem?
Many thanks!
  • pawelmwo
    pawelmwo Posts: 137
    Sounds like you need to adjust the power settings on the Shield. Try Device Preferences > Display & Sound > Power Control
    Turn off TV > when Shield sleeps off
    Sleep SHIELD > When TV input changes off
    See if that helps.
  • Raph
    Raph Posts: 3
    What you say is correct! Shield goes to sleep. But, after + - 13 seconds soundbar awakens Shield and switch on it
    Weird!
  • Raph
    Raph Posts: 3
    The support here said that's Shield that blocks the CEC system.
    I should disable all CEC options Shield. but the sound bar continues to do his thing.
    The other proposal is to connect to the HDMI 2 Shield on TV, sound bar to retrieve sound. Even that does not :-(
    Nvidia said that Polk / Denon is aware of the problem.
