Round SDA/Monitor series plates
    pitdogg2 Posts: 27,220
    edited December 2019
    Ordered the NL4MP-UC. Thanks. Thinking about getting the right angle connector
    https://www.parts-express.com/neutrik-nl4frx-speakon-spx-right-angle-cable-connector-4p--092-192
    I have them. From experience I'll say you need the binding post on top or they get in the way to turn and lock. If you have 4 binding post. P.I.T.A.
  • I was planning on having the binding posts above the Neutrik socket anyway, just looks better IMO. It takes a quarter turn to lock the connector in place if memory serves me correctly. If that's the case, I'll install the socket so that it's at the 3 o'clock position when the plug is inserted and a quarter turn to the right to lock it in place, leaving the cable pointing straight down.
    SDA SRS 2.3TL's
    SDA 2B TL's
    F1nut Posts: 51,942
    That's incorrect. Install the socket with the large tab cut out at 12 noon.
    There's no valid reason to use the right angle type unless you have your speakers one inch off the back wall, which no one would.
    VR3 Posts: 29,531
    Noted on the nl4, I usually seal around the connections and the perimeter regardless
    Yep correct. In that position the cable will be pointed at the floor with 90° neutrik connection.
  • pitdogg2 wrote: »
    Thx
    SDA SRS 2.3TL's
    SDA 2B TL's
