Round SDA/Monitor series plates
VR3
This may be one of my last runs as my life is about to get pretty hectic...
Polkie special...
normally $90 pair shipped...
$65 pair shipped CONUS
powder coated black
nl4 sda connector pre cut/punched (4 holes)
4 binding post holes, 1/4" pilot holes, matched spacing
aluminum stock
will give until the end of the week if anyone is interested... should ship within 2 weeks or so
Polkie special...
powder coated black
aluminum stock
Innerested
Trey, do you have any with two binding post holes as I purchased in 2017?
Harry"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
❤️ should I. Just in case.
I can do two binding post holes as well.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I'll buy a pair of the 2 binding post variety. Will the binding posts be located below the Neutrik opening?SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »I'll buy a pair of the 2 binding post variety. Will the binding posts be located below the Neutrik opening?
it can be if you turn it upside down or right side up.
LOL, true and I thought of that...just want to be sure that the holes won't be on each side of the Neutrik.SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »LOL, true and I thought of that...just want to be sure that the holes won't be on each side of the Neutrik.
Hole pattern I'd think would close to the same position as the first picture but with only two holes as opposed to the 4 in the picture. You get a better Idea in the second picture with the post -
Right, 2 hole plate is on bottom- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sounds good, I'll take a pair. ThxSDA SRS 2.3TL's
SDA 2B TL's -
I'm in for a pair of 4 hole Trey.
Trey, I will take a pair of 2 hole plates.
round plate, two post, neutrik, pair
PM sent with email for invoice.Post edited by BlueBirdMusic on"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
so far -
@Pitdogg2 – 4 hole + neutrik
@PTrooper – 4 hole + neutrik?
@michaeljhsda2 – 2 hole + neutrik
@BlueBirdMusic - 2 hole + neutrik
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
correct for me pal.
Roger that, they'r a "Bargain" solid and extremely professional Finnish.
Any one considering doing this in the future"buy now"!!! -
The plates are for the 1.2TL's if that makes a difference size wise.SDA SRS 2.3TL's
SDA 2B TL's -
I'm pretty sure they will fit SDA CRS and all the way upto the good old big boys but will have to get Vr3 to confirm!
Yes, Polk used the same size for just about all of their speakers until they went to the rectangle- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I'd like a pair of "two-holers", with Neutrik.Jay
Ok, no problem, will send PM.
Officially closing this one.
Thanks guys!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
invoices sent + awaiting paypal info @agfrost- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
These are currently at powder coaters, should have them back next week!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I have the plates in my possession! Hopefully will ship out Saturday or Monday!
Thank you for your patience- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Which Speakon chassis mount should I install?
https://www.parts-express.com/Search.aspx?keyword= Speakon Connector 4 Pole Panel Mount&sitesearch=true
or this one?
https://www.parts-express.com/neutrik-nl4mp-st-speakon-connector-4-pole-panel-mount--092-053
or something different...SDA SRS 2.3TL's
SDA 2B TL's -
Either of the nl4mp are fine.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thanks Trey.SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »Which Speakon chassis mount should I install?
or this one?
It does matter. The second choice is NOT air tight and that is a problem. This is the one you want, Neutrik NL4MP-UC.Political Correctness'.........defined
President of Club Polk -
Yeah I was reading a previous post about that after I ordered them...calling to cancel order.SDA SRS 2.3TL's
SDA 2B TL's -
Ordered the NL4MP-UC. Thanks. Thinking about getting the right angle connector
https://www.parts-express.com/neutrik-nl4frx-speakon-spx-right-angle-cable-connector-4p--092-192SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »Ordered the NL4MP-UC. Thanks. Thinking about getting the right angle connector
Other than my personal dislike of that design they only accept cable diameters of between 1/4" to 1/2". Some of the straight designs accept larger diameters and are easily enlarged if need be.Political Correctness'.........defined
