New McIntosh Monoblock Amp
mark090852
I found this very interesting.
McIntosh new MC901 Dual Mono Amplifier.
The MC901 is a monoblock amplifier that drives a single speaker. But it is unlike any other monoblock amplifier. What makes the MC901 so unique is that it's two amplifiers combined into one. Adding to the uniqueness is that each amplifier is of differing design philosophies: the MC901 consists of a 300 Watt vacuum tube amplifier attached to a 600 Watt solid state amplifier on one unified chassis.
McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
Well that is interesting! So is it 900wpc? 8ohm specs at 4ohm?
She is a looker -
Well maybe the SS for low end and tubes for highs.
I see taps for SS and taps for Tube... Weird.Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
Glass must be getting expensive as they only use it for the meter face...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I have a feeling a pair of those would cost as much as my house.Gustard X26 Pro DAC
must be class d on the solid state end as it may not have enough heat sink area.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I'll bet 10.00 that there is it's purpose.
I'm not into tubes yet but from what I've read, this design makes sense to me.
Now..., do they have a mixed Pre-AMP too?Most people just listen to music and watch movies. I EXPERIENCE them.
nooshinjohn wrote: »Glass must be getting expensive as they only use it for the meter face...
I think there's a little bit in the tubes, too... but, of course, Mac doesn't make the tubes.
Appears to be a MC2301 and MC601 rolled into one chassis. Wonder how the power supply is split up, or if it is.
Where did you see this?
EDIT: I found it on the www. Interesting product. It is built for bi-amping and contains a cross-over. $17.5K each and 29.5" deep.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources. -
Here's a bit more info on them.....I say kudos to Mac's engineering dept. for coming up with a statement piece like this
Announcing the McIntosh
McIntosh is proud to announce the new MC901 Dual Mono Amplifier.
Legendary home audio company McIntosh has been perfecting vacuum tube amplifiers since the 1940s and solid state amplifiers since the 1960s. Their amplifiers have been used at many historic events including presidential inaugurations and Woodstock, as well as in landmark sound systems like the Grateful Dead's Wall of Sound and Despacio. From that heritage comes a truly one-of-a-kind home audio amplifier only they could dream of, design and build as the ultimate solution for bi-amping loudspeakers: the new McIntosh MC901 Dual Mono Amplifier.
The 300 Watt vacuum tube portion powers the speaker's mid and upper drivers via eight KT88 output tubes, plus four 12AT7 and two 12AX7A signal tubes; the solid state section delivers 600 Watts of dedicated power to the power hungry woofers. The 300 Watt vacuum tube amp in the MC901 uses McIntosh's patented Unity Coupled Circuit output transformer – the same technology McIntosh was founded on in 1949 – to deliver its full 300 Watts into almost any speaker regardless if it has 2, 4 or 8 Ohm impedance. Similarly, the 600 Watt solid state amp delivers its full 600 Watts into a 2, 4 or 8 Ohm impedance speaker via McIntosh's Autoformer™ technology.
Vacuum tubes do not perform at their best when they are amplifying lower frequencies that are not being used by the loudspeaker. With the MC901, the vacuum tube amp will not be burdened with low end reproduction as the solid state section will drive these frequencies. The two amplifier sections of the MC901 are designed to work together in a synergistic relationship and are specifically engineered to assure that each section only amplifies its intended frequencies. Each amplifier section has its own discrete power supply so neither siphons power or performance away from the other. All of this results in easy bi-amping with unparalleled performance and sound reproduction from the speakers.
Prior to the MC901, bi-amping a speaker required two separate amplifiers. It also required an external crossover, along with a lot of trial and error, to properly configure the two detached amplifiers so they worked together as best as possible. The MC901 solves this issue thanks to its internal, adjustable crossover with the controls easily accessible on the top of the unit. These adjustable crossover filters allow the user to optimize the performance of both amplifier sections to their listening preferences. Relative gain levels for each amplifier section can be adjusted from -6dB to + 3dB. A direct feed can also be connected to each amplifier section, thus bypassing the filters.
Like virtually all McIntosh amplifiers, the MC901 features an iconic "McIntosh Blue" Watt meter, which has come to be recognized around the world as a symbol of quality audio. And just like the MC901 itself is a new design, so too is its meter with the introduction of McIntosh's new DualView™ Power Output Meter. The DualView meter features two of McIntosh's traditional, fast responding mechanical meters stacked above and below each other in a single meter window; one meter is dedicated to the 300 Watt vacuum tube amp and the other to the 600 Watt solid state amp. Each meter operates independently of the other and displays the real time power reading of each amplifier section.
While an entirely new design, the MC901 comes with the technology one would expect from a McIntosh amplifier: Power Guard® in the 600 Watt solid state amplifier section, Sentry Monitor™, Quad Balanced design, Power Control, Solid Cinch™ speaker binding posts, McIntosh Monogrammed Heatsinks™, and McIntosh's eco-friendly Power Management System.
A brand new technology in the 300 Watt vacuum tube amplifier section of the MC901 is Power Guard Screen Grid Sensor™ (SGS). Power Guard SGS™ helps prevent premature vacuum tube failure by monitoring the screen grid current in the KT88 output vacuum tubes. If the current becomes too high, a circuit in Power Guard SGS is activated which then dynamically attenuates the input signal in real time to keep the vacuum tubes operating at safe levels.
Although the MC901 may look different than any McIntosh product before it, a quick glance reveals signature McIntosh design cues. The top is highlighted by a series of diagrams printed on glass that outline the basic circuitry and specifications of the unit, along with a glass nameplate trimmed with a circular aluminum ring that's finished to match the front panel endcaps. The sides are adorned with vintage McIntosh-styled die cast aluminum name badges. Two classic McIntosh knobs are located on the front of the polished stainless steel chassis, and direct LED backlighting illuminates the DualView meter, McIntosh logo and the lettering on the black glass front panel. The uncompromising level of fit and finish that is expected of a McIntosh product completes the MC901.
Unit Dimensions (W x H x D):
17-1/2" (44.5cm) x 13-1/4" (33.7cm) x 29-1/2" (74.9cm)
Shipping Dimensions (W x H x D):
24-13/16" (63cm) x 18-3/8" (46.7cm) x 36-1/4" (92.1cm)
Unit Weight:
170 lbs (77.1 kg)
Shipping Weight:
190 lbs (86.2 kg)
Expected to begin shipping December 2019
• US MSRP: $17,500 each Mono Amplifier
A one-of-a-kind, ultimate solution for bi-amping loudspeakers with dual inputs
__________________ -
Wow! That's all I got.
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Damn, it looks like I won't be able to get one. 29" deep. There is no way that will fit in my Salamander cabinet. Oh yeah, there is also one other little thing that prevents me from acquiring it: $17,500.
Bus, as Verb so elonquently stated, Wow! -
170 lbs each. That's some weight! Interesting design. I would give it a listen.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
out of the box thinking. Lets see how many other manufacturers follow suit. An interesting design.[
are there that many manufacturers that do both solid state and tubes ?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
No doubt this will trickle down somewhat.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
if I were playing in this price arena, don't think I would be looking at McIntosh.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I agree Marv. The McIntosh rooms are beautiful but I've never walked away with the goosebumps from the intoxicating sound. -
@motorstereo,
I encourage you to buy a pair of these so that I can drop by on my next trip to NJ from NH. I'd love to hear how they drive your pair 1.2tls.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
Thanks for the encouragement Phil and honestly I'd love to hear them on a pair of 1.2tls........just not mine
Perhaps you could be the first one in CP to land a pair?? It would be my pleasure to head to NH to help you wrestle those beasts in -
I think @Mpitogo needs theseThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
motorstereo wrote: »Thanks for the encouragement Phil and honestly I'd love to hear them on a pair of 1.2tls........just not mine
Brian,
If I thought I could persuade my wife that for some reason I [we] really NEED a pair of these monoblocks, I would be tempted to try.
But, I am pretty sure I wouldn't have the proverbial prayer to succeed in that endeavor!
Happy holidays, @motorstereo.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
I don't get how their internal crossover works if you biamp these to a speaker. When you biwire with a regular amp you send the signal to the tweeter for the highs and the same signal to the mid /bass woofers. Its the speakers crossover that determines the crossover point to give a flat response.
With an additional crossover in the amp how do you get it exactly match with the speakers crossover points and give a flat overall response? You would need to have it at the exact crossover point as the speakers and hope both crossover curves have the same "order". A first, second, and third order crossover can have the same cutoff point but they all have a different slopes. I will bet that if you measure the speakers response with this kind of setup there will always be some kind of blip at the crossover point.
What am I missing? -
2 issues
1) fugly
2) I don’t do tubes- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
- Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.1 B&W Formation Duo and Bass
- Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
- Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
- Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
2 issues
1) fugly
2) I don’t do tubes
Tunes RULE... if you don’t have tubes in your rig somewhere, you don’t know what you’re missing.
What am I missing?
When using an active crossover you take the passive crossover in the speaker out of the signal path.Political Correctness'.........defined
President of Club Polk -
What am I missing?
That would make more sense but I wonder how many people will rip the guts out of their ultra high end (and extremely expensive) speakers?
One more question. The tubed part puts out 300 watts. Can you even put that much power to one tweeter? -
Understand this completely, but.....
If someone did go nuts and pair these with a nice set of 1.2tl's, would that not kill the entire concept of SDA? Without a focused engineering effort, there would be no way to reap the full "benefits" of the investment with any SDA speaker.
Am I missing something?Media Room: Parasound JC-5, Cambridge 851N, Schiit Freya, SDA SRS 1.2tl
Game Room: Carver M4.0t, Carver C-4000, Oppo BDP-105, SDA SRS 1.2tl
Bar/Card Room: Carver TFM-55, Carver C-1(BillD), Oppo BDP-93, SDA SRS 3.1
Son's Room: Carver TFM-55, Carver C-1(BillD), Laptop/AQ Dragonfly, SDA SRS 3.1
Bedroom: McIntosh MC150, Cambridge CXN, SDA 2Btl
Outdoor Pool Area: Yamaha R-N803 with four Polk Atrium 6
HT: Polk RTi A9s, CSi-A6, RT-65, RTi-A3's, Marantz SR5012, XPA3, UDP-203, Epson 5040UB -
If you do have tubes in your rig, you probably haven’t heard world class solid state.
I had a world class SS amp - I came back to tubes.[ -
I thought MasterSound was the best ever...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
