Qobuz Question
msg
Is a Facebook account really required to create Qobuz account?
I paid for a year in advance and they never asked me about Facebook. I really like the service.
No but you can use Facebook to sign up for it- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
No, using your Facebook account is just one way to sign up, but it is not necessary.
McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers. -
Thanks guys, brain-f on the sign-up page.I disabled signatures.
So whats the verdict?Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Have you found many bands missing that you want?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Okay, took some PT this morning to see to a few things, and set this up real quick. I'll get some muzak set up an' gib it a proper wissen.
Miles Davis Quintet - The Legendary Prestige Quintet Sessions started playing automatically, so I'm going with it.I disabled signatures. -
Make sure you checking the high rez stuff out on there. I am not sure what app you are suing but, on my Lumin, Lightning and Mcontrol apps, they state hi rez on the icon.Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
I'm using a computer, smartphone and will later this eve set up the Qobuz plug-in on LMS for the Squeezeboxes. I think that's limited to 24/96. I can probably figure out something to play high-res with on the main system.
Here's the settings page for the app. There is an option in there for > than 96. I presume this means greater than 96k. I'll play around with it to see how it works.
They do also have some higher then that but that's a startMusical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
I see the 24/192 option in the apps they have, but on the LMS plugin setup, it's not shown as such. I think the >96 may be the higher resolution stuff. I'll see how it goes if I try to play it and do some reading.
I'll check it out on the month trial. Need to see about getting some playlists imported. I think I used Soundiiz for this before when I was checking out Tidal and converting from Spotify for head start.I disabled signatures. -
Streaming hiRez through Q immediately changed the “bit rate display“ on my DAC, whereas that never happened with TidalSo whats the verdict?
I hope the pricing of their new tiered structure stays the same after the new yr.Have you found many bands missing that you want?
Source Lumin U1 Mini into Lampi Baltic 4
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Wrong thread. At least I’m in the ballpark🤣AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
All good. I also use it to find nee or different music.Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
