Stereo sounds so good
BlueFox
It has been on since Thursday night, and is definitely warmed up. Currently playing classical string quartet music, and I am in heaven. Later I will switch to some form of rock, and that will also be heavenly. Once the night is over the stereo will be powered off until next weekend.
How can you not have music on for five days?!?
And which strings pieces are you enjoying?I disabled signatures. -
Currently this is playing. There are 919 tracks in the Classical playlist.
Three 20 amp circuits. -
Also, if I am not seriously planted in front of the stereo listening to it for hours it isn’t turned on. It uses as much electricity idling as it does playing, and I try to keep my electric bill close to zero.Lumin X1 file player, Westminster Labs interconnect cable
DSC_1532 by Mark Hardy, on Flickr
Mine's close to zero -- and you get a bit more sunshine than we do here.
Just sayin'.
But, yeah, everything here is turned off when not in use, as well. I've turned into my father as I've aged. He would turn off a light if someone else walked out of a room, if only for a moment. Or, at least, it seemed like it.
It is winter, and raining. Not much solar is generated. In the spring, summer, and fall the stereo generates so much heat that the AC has to run. When both the stereo and AC are on it uses more electricity than the solar generates.Lumin X1 file player, Westminster Labs interconnect cable
Shostakovich is now playing.
Would a less demanding "background" system offend your ears? I have my HT/2 ch playing most of the time. It is not as good as my main system and I even sit and listen to it sometimes. The main system is in the bedroom and I don't listen to it much as I don't want to become a "bed tuber". -
My second stereo and HT system fits that scenario, but I don’t spend much time in that room.Lumin X1 file player, Westminster Labs interconnect cable
Nice house!! Would you happen to have a recording studio in one end of it? I watch a lot of Live From Daryl's House and your house sure looks a lot like Daryl's.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Time to spend the rest of the night listening to Rock. Starting with Marilyn Manson.
He's never even stopped by!
