Stereo sounds so good
It has been on since Thursday night, and is definitely warmed up. Currently playing classical string quartet music, and I am in heaven. Later I will switch to some form of rock, and that will also be heavenly. Once the night is over the stereo will be powered off until next weekend.
    msg Posts: 10,532
    edited December 2019
    How can you not have music on for five days?!?
    And which strings pieces are you enjoying?
  • BlueFox
    BlueFox Posts: 15,250
    Currently this is playing. There are 919 tracks in the Classical playlist.
  • BlueFox
    Also, if I am not seriously planted in front of the stereo listening to it for hours it isn’t turned on. It uses as much electricity idling as it does playing, and I try to keep my electric bill close to zero.
    mhardy6647 Posts: 35,364
    BlueFox wrote: »
    27974237967_b90f44446f_h.jpgDSC_1532 by Mark Hardy, on Flickr
    Mine's close to zero -- and you get a bit more sunshine than we do here.
    Just sayin'. ;)
    But, yeah, everything here is turned off when not in use, as well. I've turned into my father as I've aged. He would turn off a light if someone else walked out of a room, if only for a moment. Or, at least, it seemed like it. :p
  • BlueFox
    It is winter, and raining. Not much solar is generated. In the spring, summer, and fall the stereo generates so much heat that the AC has to run. When both the stereo and AC are on it uses more electricity than the solar generates.
  • BlueFox
    Shostakovich is now playing.
  • afterburnt
    afterburnt Posts: 7,892
    BlueFox wrote: »
    Would a less demanding "background" system offend your ears? I have my HT/2 ch playing most of the time. It is not as good as my main system and I even sit and listen to it sometimes. The main system is in the bedroom and I don't listen to it much as I don't want to become a "bed tuber".
  • BlueFox
    My second stereo and HT system fits that scenario, but I don’t spend much time in that room.
  • TennMan
    TennMan Posts: 1,266
    Nice house!! Would you happen to have a recording studio in one end of it? I watch a lot of Live From Daryl's House and your house sure looks a lot like Daryl's. :)
  • BlueFox
    Time to spend the rest of the night listening to Rock. Starting with Marilyn Manson.
    TennMan wrote: »
    He's never even stopped by! ;)
